The Big Bang????
Old Jan 22, 2004 | 09:15 AM
killer89's Avatar
The Big Bang????
In the Evos in general....
When the timing belt snaps, does the whole engine go too? Meaning when the belt snaps, do the valves have any clearance from the pistons or not? If no, then you'd have a big problem with blown up motors...
Thx,
Erik
Old Jan 22, 2004 | 09:23 AM
yycools's Avatar
yes, with 4G63 engines, timing belt snaps, your motor goes with it.
Old Jan 22, 2004 | 10:38 AM
metaphysical's Avatar
Registered User
That's the case with most engines just for references. Timing chains have problems also. We've had cars that this has happened to that only destroyed the head.
Old Jan 22, 2004 | 02:42 PM
mobius97's Avatar
The 4g63 is an interference engine....so bye bye birdie!!!!
Old Jan 22, 2004 | 03:07 PM
Secret Chimp's Avatar
There are lots of non-interference engines out there. But I believe the Evo engine is of an interference design. So when the belt snaps, you could have some crushed valves and damage to other spinning parts.
SC~
Old Jan 22, 2004 | 06:59 PM
w2pac12345's Avatar
how often should you changed the belt if your pushing 350 WHP or 400 WHP?
Old Jan 22, 2004 | 07:20 PM
Quickshift's Avatar
get a kevlar belt if you do change it..
killer89's Avatar
dang... that is a huge problem... My family was considering buying the Evo, but just that right there might've been the big red STOP sign...
Old Jan 22, 2004 | 07:22 PM
tweakdsm's Avatar
chain!!
Old Jan 22, 2004 | 09:03 PM
ItsStockOfficer's Avatar
The change from chains to belts was a huge techinal innovation.
And why would this stop you from buying an EVO? If you don't change you belt, it breaks. Kinda like, if you don't fill your oil, it siezes. Such is the way of life.
Old Jan 22, 2004 | 09:04 PM
NOVA EVO's Avatar
It doesn't make that much of a difference from stock...the timing belt just turns the cams...it is not in the actual drivetrain.
Old Jan 22, 2004 | 10:51 PM
timzcat's Avatar
Not that it makes a big difference anyway but it's the torque that will affect the belt. That and the additional RPMs if you've bumped that up.
Old Jan 22, 2004 | 10:57 PM
BadBoyBeltran's Avatar
Most cars, if the timing belt breaks, you will at the very least bend the valves. The EVO has a 5 year powertrain warrantee. The timing belt is one of the last things you should worry about in any car.
Just get it replaced around the 50,000 mi mark or whatever the manufacturers suggested time period is.
Old Jan 22, 2004 | 11:04 PM
Noize's Avatar
EvoM Administrator
These new belts are a lot better than the ones in the 1G cars. The belt interval is 105,000 miles or something crazy like that.
Old Jan 23, 2004 | 04:36 AM
chuntington101's Avatar
Mate, with any modified engine with a belt, you need to check the belt regularly. I would say check the thing at EVERY service interval (around 5000 miles) that way if there is any signs of premature wear, you can hopefully get it resolved before the BIG BANG!
