installing manley piston rings
Old Apr 13, 2012 | 10:36 PM
evoyrrah's Avatar
im in the process of putting my motor together and got to installing the rings. i opened the packet and found 5 rings. 3 are for the oil ring as expected, 1 was for bottom ring with a dot and bevel so i can see how that goes, top ring is identified by silver/grey outer edge but has no dot or bevel saying which side faces up? so i can assume that it goes either way? biggest problem is... there is a separate 5th packet with 4 of the same black rings instead of being distributed in the other 4 packs of rings. these rings have a petruding dot on one side and an intruding in the same spot on the other side with no bevel????what the hell these for? it looks tighter than the rest because the ends over lap......any ideas??
Old Apr 13, 2012 | 11:44 PM
gt42r's Avatar
The 5th packet bro are the oil rail supports,they are not piston rings.I suppose your engine is a stroker and Manley's stroker pistons use oil rail supports.If you read the instructions carefully you will notice that.
Old Apr 14, 2012 | 12:04 AM
evoyrrah's Avatar
yeh ur right but what they for? do we use them for our evos or are they for subarus or something? or do i have to use them being stroker pistons?? if this is true then they would replace the bottom oil ring? the data sheet isnt very clear at all
Old Apr 14, 2012 | 12:44 AM
gt42r's Avatar
Since you have stroker pistons you have to use them.If you measure the oil ring space on the piston you will see that it has exactly the space for the oil ring AND the oil rail support.The support is placed at the bottom of the oil ring .
Old Apr 14, 2012 | 02:18 AM
evoyrrah's Avatar
So it's used instead of the othe bottom oil ring? Or added on as a 4th oil ring? 4g64 long rod pistons ARE stroker pistons right?
Old Apr 14, 2012 | 03:40 AM
gt42r's Avatar
As a 4th oil ring and supports the 3 oil rings.Yes,4G64 long rod have stroker compression distance.
Old Apr 14, 2012 | 08:06 AM
evoyrrah's Avatar
i just didnt expect that! a 4th oil ring.....gamithica
Old Apr 14, 2012 | 08:34 AM
gt42r's Avatar
hahaha!!!me too gamithica in the beggining but then I figured it out,haha!!if you need any more help pls tell me bro!
Old Apr 14, 2012 | 10:14 AM
NewEvolutionIX's Avatar
What are you running for ring gap for stormer high horse motors
Old Apr 14, 2012 | 05:51 PM
evoyrrah's Avatar
Hahahaha After doin the calculation on the sheet ring gap worked out to be 3.4251x.0045"=.0016 ring gap........sound right?
Old Apr 14, 2012 | 06:45 PM
RSMike's Avatar
16 thou sounds a bit tight.
I ran 17 thou top right with 86mm Mahle pistons - low expansion alloy.
Old Apr 14, 2012 | 07:28 PM
evoyrrah's Avatar
Really? Maybe I should go to .0017"?
Old Apr 14, 2012 | 07:36 PM
RSMike's Avatar
shouldn't you be multiplying by 0.0055?
Rather than 0.0045?
This will give you 19 thou top ring.
Old Apr 14, 2012 | 07:57 PM
evoyrrah's Avatar
Should I? I went of street strip formula which is x.0045".... Should I be goin for blown alcohol gaps??
Old Apr 14, 2012 | 08:02 PM
evoyrrah's Avatar
Also thanks for these suggestions and advice cos this the first motor I'm putting together and I wanna do it right.... Keep them coming )
