GSC S2 Cams Sharing...
Old May 2, 2012 | 09:11 AM
jameswwt's Avatar
Hi,
im sharing this info that my friend have managed to improved his car low end response after he advance a tooth on his GSC S2 cams on his 2L engine with a GT35R turbo.
Its a obvious result and to surprise the mid and top end done seem to lose much power either.
Old May 2, 2012 | 09:33 AM
C6C6CH3vo's Avatar
Was that the Intake cam? Anyhow, This is why we have adjustable gears.
Old May 2, 2012 | 09:39 AM
okevolutionVIII's Avatar
I'd do an adjustable cam. I use a piece of tape on the timing belt and mark where the timing mark is on the cam gear, then swap the gears while holding the belt to prevent slack. It'll take about 10 minutes once the valve cover is off to break the cam gear bolt loose. I did all this without using a timing belt tensioner tool.
Old May 2, 2012 | 11:42 AM
jameswwt's Avatar
No, its the Exhaust cam...I thought it should be greater if it was Intake cam.
midegade
Mar 22, 2017 04:17 PM
Alexevo09
Apr 27, 2016 02:16 AM
krahman95
Dec 11, 2015 10:20 AM
bosco121
12
Jun 26, 2012 09:57 AM
jameswwt
Oct 22, 2010 04:45 AM
