How can you tell when your oil pump fails?
Old May 11, 2012 | 10:02 AM
88888's Avatar
So i have a prosport gauge. it was working fine until yesterday and all the sudden its stuck at 0psi and sometimes 30psi now for some reason.
Its stuck no matter how fast, what rpm im in
Im pretty sure its the gauge but for my own information, how do you know when your oil pump has failed?
Old May 11, 2012 | 10:07 AM
barneyb's Avatar
The engine looses power, throws a rod or locks.
Old May 11, 2012 | 10:09 AM
LOVEBOOOST's Avatar
what barney said...U will know after u loose oil pressure. U will see a big window in ur block and most likey a rod short of 4!!!
Old May 11, 2012 | 10:24 AM
foxbear2277's Avatar
Oil pressure loss is the first and most important sign. Thats why oil pressure gauges are available. Have to protect your inveetments glad you have one, definently check oil pressure with a different gauge to really tell if its the gauge or the pump.
Old May 11, 2012 | 01:08 PM
Davo's Avatar
i know prosport had some failing sensors
sure the prosport sensor isn't shot?
does your factory oil light on dash stay on while idling?
Old May 11, 2012 | 03:36 PM
stinkbomb's Avatar
heres how i knew the oil pump gear broke in half, while idling in my drive way
Old May 11, 2012 | 09:32 PM
^^^^^^^^HOLY TOLEDO...and while idling, fail!!!!!!!!!!!!
Old May 11, 2012 | 09:42 PM
EvoDan2004's Avatar
If the gauge is reading 0 then 30 and back to 0 and your FACTORY oil light is not on then my guess would be the gauge sensor is shot. if the factory oil light is on do not start the car. replace the pump
i would drain the oil and check it. make sure there is nothing in it. put new oil in the car and get a new gauge.
Old May 12, 2012 | 06:40 AM
tsidrift1's Avatar
Sensor is gone. When I was running prosports on my first evo, I went through 3 sensors for those damn things. When you get a new sensor, I recommend getting a remote line that places your sensor away from the filter housing. They say the vibration kills the senders.
Old May 12, 2012 | 08:36 AM
bnr34rb26dett's Avatar
thats good to know. are you talking about hte actual sensor or the gauge? i just bought myself a nre one already.
i have already gone through the oil temp sensor too....
thanks for the input guys it helps a lot
Old May 12, 2012 | 09:18 AM
tsidrift1's Avatar
The sensor/sender. The unit that most usually install into the oil filter housing.
Old May 12, 2012 | 09:20 AM
EVO(boss)'s Avatar
u gonna hear sound like clik clik clik clik which is ur bearing ..
hayden81
48
Apr 26, 2018 07:57 AM
suprPHREAK
Toronto Lancer Club
62
Dec 15, 2016 10:17 AM
tscompusa
E85 / Ethanol
92
Oct 12, 2016 06:16 PM
acssa
11
Apr 2, 2013 10:22 AM
TakaseEVOIXSE
10
Apr 16, 2009 08:49 AM
