Compression Test Results, any advice?
Old May 13, 2012 | 06:24 PM
silver_evo's Avatar
Question Compression Test Results, any advice?
03 Evo 8 with 83K miles with Kelford 272's.
Engine at operating temp with throttle 100% open
Dry : 110-115-90-115
Wet : 190-190-160-255
I was highly confused about the 255, but saddened by the 160 wet test.
I plan to do a rebuild at 120K. I think the years to tuning with running 1-3 counts of knock has caused damage to the #3 piston rings.
No noticable buring of oil or any symptoms of a HG failure.
The numbers are low, but I blame the cams for the low overall pressure.
Let me make sure I got this right before I do the next step.
A cylinder leak down test consists of removing the #3 plug with #3 cylinder at TDC, using a fitting/adapter and pressurize the cylinder with shop air (100#)
Air escaping from the TB is intake valve seal.
Air escaping from exhaust is exhaust valve seal.
Air escaping from oil cap is piston ring blow by.
Thanks for the look and advice.
Old May 13, 2012 | 07:18 PM
mithrandir7533's Avatar
If those numbers are accurate, I don't think you will make it to 120k miles before your rebuild. You want the numbers to all be within 10% of each other. I would be worried about the 255. I'm not experienced enough though to comment on what the problem could be. I would double check your numbers!
Old May 13, 2012 | 07:23 PM
mt057's Avatar
Get a leakdown tester. I don't really even bother with the compression test anymore. The leak down will let you know what you need to know and takes about the same amount of time. I bought my tester for about $100 if I remember.
Old May 13, 2012 | 07:44 PM
silver_evo's Avatar
Yeah, I was looking at the leak down testers, they have a pressure gauge and a % leak gauge. I'm going to see if I can rent/check one out from my local parts store.
Old May 13, 2012 | 07:50 PM
silver_evo's Avatar
As for the mileage, 120K was an estimate on rebuild because I would be due for a timing belt again. I mainly drive my motorcycle around to save gas. I maybe drive 100 miles a month on the Evo, I want to wait until I'm back on the mainland before I tear it apart again (3 years). Lack of machine shops and expensive shipping makes a rebuild in Hawaii a bad idea.
Old May 13, 2012 | 07:52 PM
Anarchy99's Avatar
Not possible to have 255 psi pressure in cylinder 4
Old May 13, 2012 | 07:56 PM
silver_evo's Avatar
Yeah, I thought it was weird too. I did the test twice. I may have put too much oil in the cylinder, it was maybe 1 oz. which would've reduced the volume resulting in higher pressure, but I doubt 1 oz would make that much a volume difference.
I did that cylinder twice to make sure, then I did the 160 again to make sure the gauge didn't break. It was accurate.
Old May 17, 2012 | 03:36 PM
killercd4G63's Avatar
Veteran: Army
agreed
how
Old May 17, 2012 | 04:19 PM
mcm308's Avatar
Im no pro by any means but I could see excessively high psi with too much fluid in the combustion chamber with an interference engine like these. Try again with 1/2 ounce fluid in all cylinders and compare numbers.
ISPEVO8
Feb 27, 2017 07:01 PM
Drift4
26
Sep 2, 2016 11:31 PM
2e0v0o3_8
45
Apr 7, 2016 11:02 AM
nukleus
18
Jan 8, 2016 04:05 PM
evo_soul
Toronto Lancer Club
Apr 6, 2011 07:40 PM
