Having issues with wastegate actuator
Old May 21, 2012 | 02:45 PM
Brent_si's Avatar
I just finished installing an external dump o2 housing on my evo. Well now it sounds like the wastegate is stuck open. The first time I got into boost it went over 30psi and hit boost cut. Is there any tricks to fix it or just buy a new one?
Old May 21, 2012 | 03:26 PM
mt057's Avatar
What are you using to control boost? What is your target boost level?
Old May 21, 2012 | 03:30 PM
Brent_si's Avatar
Its a hallman pro mbc. My boost was at 24psi before. Wastegate must be stuck open because sounds like I have a big exhaust leak.
Old May 21, 2012 | 03:39 PM
AWDBus's Avatar
Have you tried adjusting it yet?
Old May 21, 2012 | 05:08 PM
Brent_si's Avatar
You can adjust it?
I really had no idea. Came from a built stroker turbo honda with external wg. No idea about the internals. More info would be good.
Also want to add that I can pull the arm on the actuator and it does move. From the last one i replaced that was bad it would not move at all.
Old May 21, 2012 | 05:13 PM
fightex's Avatar
Did you install the (divided) gasket that came with the dump? Because if you installed a regular undivided gasket exhaust gas will escape from the turbine through the dump.
Old May 21, 2012 | 05:14 PM
Brent_si's Avatar
yes I did. And that woudln't really explain the over boosting.
Old May 21, 2012 | 05:45 PM
mt057's Avatar
Try taking the mbc out of the equation. Run your vacuum line directly from the boost source to the wastegate and see what that does.
Have you tried to actuate the waste gate with a hand pump or something similar to see when it opens?
Old May 21, 2012 | 05:54 PM
Brent_si's Avatar
I will try to run the line from turbo to wastegate and see what happens. No never tired to us a hand pump.
Old May 21, 2012 | 06:58 PM
Brent_si's Avatar
Anyone had this issue after a o2 dump install? It is a vsrf/muse by the way. How do you adjust the actuator?
Oh and i can hear the exhaust get louder through the dump so i would assume its opening but boost still goes to high.
Old May 21, 2012 | 07:03 PM
211Ratsbud's Avatar
What turbo?
Old May 21, 2012 | 07:33 PM
Brent_si's Avatar
Originally Posted by 211ratsbud
What turbo?
Stock evo 8 9.8t
Old May 22, 2012 | 05:17 AM
Brent_si's Avatar
I really need help on this. would adjusting the wastegate actuator fix this issue?
Old May 22, 2012 | 08:46 AM
211Ratsbud's Avatar
did you try to run a direct line yet. We need to know what psi your wga is at. If you can hear exhaust at idle from this then you have a bad gasket or waste gate.
Old May 22, 2012 | 08:50 AM
Brent_si's Avatar
No haven't had a chance to do it yet. I will tonight after work. But this issue did not arrise until the external dump was installed.
