E85 question...
Old May 23, 2012 | 02:22 PM
ElectricBlueIX's Avatar
E85 question...
So I was wondering, since I'm new to E85, if I need a bigger injector to run it. My current setup is in my signature. Turbo is completely stock along with a Wally 255hp and FIC 1050's. I made a tad over 400whp on AWD's dynojet on 30lbs and 110 octane race gas. I've been told the car would probably make more on E85. Do I need a bigger injector though? I figured with stock turbo I should be fine but I wanted to make sure before I got the car tuned again.
Old May 23, 2012 | 07:03 PM
Any thoughts? Suggestions?
Old May 23, 2012 | 07:20 PM
CurseDSM's Avatar
On a stock turbo I'd say no. Fic 1050s are good injectors and should be more then enough for e85. There is a formula you can use. cfm x .33 = x, take x and add it to the cfm and it gives you what injector size it should be so in your case figure 650x.33=214.5 then add the 214.5 to 650 and that gives you 864.5 so 1050s should be more then enough for your setup.
Old May 23, 2012 | 07:40 PM
evotuner04's Avatar
15 Year MemberLikedLoved
Im running 1000cc and im good and mines tuned on a mustang dyno
Old May 23, 2012 | 07:41 PM
uvambo's Avatar
You should be fine, you will run out of turbo before you run out of injector...those will support more than that turbo should make
Old May 23, 2012 | 09:37 PM
cmspaz's Avatar
Mine sit right around 70% duty cycle at current, I should have no problems turning it up.
Old May 23, 2012 | 09:44 PM
asu11's Avatar
Just curious how you are keeping your tq down with an ix turbo? Ecu boost?
Old May 23, 2012 | 09:50 PM
Ok thanks guys. I was thinking I wouldn't need more injector with stock turbo. My next set of mods will probably be o2 housing, hard intake pipe for SD setup, and might port the turbo.
