Car will not idle after BF272 install
Old May 24, 2012 | 11:12 AM
ilikeppie's Avatar
I can not figure out why the car will not idle. If you even breath on the throttle it will run but if you fully let off it dies. I have checked the timing, boost leak tested adjusted the throttle body screw tried changing the injector scaling and latency nothing is helping or seems to be changing anything at all. any help is appreciated.
Old May 24, 2012 | 11:28 AM
okevolutionVIII's Avatar
I would:
Raise idle to 1000-1100 rpm
Move timing to 10* at idle
Add a few % fuel at idle
Double check cam timing
Old May 24, 2012 | 11:46 AM
el.guerrero's Avatar
Originally Posted by okevolutionVIII
I would:
try before of all same rom only raising idle to 100/1100 then
go step by step as suggest by okevolutionVIII.
Old May 30, 2012 | 06:31 AM
ilikeppie's Avatar
solved, it was an issue with the IAC valve
