Turbo coolant hard line keeps cracking. What gives?!
Old May 29, 2012 | 05:14 AM
Macaroni's Avatar
I have replaced my turbo coolant hard line due to it constantly cracking right at the first bend after the banjo bolt. They usually last around 3-5 months before cracking again. Is their an underlying issue here or should I just switch it out for a SS line?
It's a 84mm journal red for what it's worth.
Old May 29, 2012 | 08:55 AM
turbolarry's Avatar
Is the turbo/O2 housing supported and bracketed to the block?
Old May 29, 2012 | 09:47 AM
EvoVIIIFL's Avatar
That's got to be the weirdest thing ive ever heard...I just recently upgraded my coolant lines after using just normal coolant lines from napa with only one crack after 3 years of use...only thing I could think is your temps might be running very high that could cause quick degredation of the lines?
Old May 29, 2012 | 10:24 AM
Macaroni's Avatar
I don't have any bracing from the turbo system to the block but vibration would be the same on that line as it is on the turbo, manifold, o2 housing, and downpipe.
High temps might be a cause of it I'm running a half radiator and the temps run higher than traditional +/- 180*
I'm thinking of changing it out for a braided line to see if that does anything.
grim~
Jan 22, 2016 06:05 PM
Luminox
Sep 2, 2014 03:03 AM
Blitz
May 16, 2014 08:43 AM
BoosTyEVO
Apr 19, 2013 06:31 PM
