Which Injector Brand???
Old Jun 3, 2012 | 06:17 PM
foxbear2277's Avatar
Originally Posted by jameswwt
Btw, by using s larger injector will it consume more fuel? Some say their car consume lesser fuel with a smaller cc injector compare to bigger injector with same power band.
Should not consume more fuel if properly tuned... for instance I will be running ID 2000, overkill on my part indeed, but they give me room to grow and they can easily tuned for a lower duty cycle/hp level
Old Jun 3, 2012 | 06:32 PM
jameswwt's Avatar
Really? Thanks Foxbear as i thought the bigger size injector spray more fuel on the same given time.
Old Jun 3, 2012 | 06:46 PM
They have to be tuned... If you have 1000cc and 2000cc injectors both at 80% duty cycle then yes the 2000cc will spray alot more... ID are known to be great to be tuned safely and reliably at lower duty cycles
2000cc injectors on a 120 hp
Old Jun 3, 2012 | 06:54 PM
Bigger injectors have bigger orfices to allow more fuel to enter the system. when bigger then needed injectors are used then the duty cycle will need to be lower to ensure the orfice is opend for a shorter time when compared to a smaller injector
Old Jun 3, 2012 | 07:51 PM
Race Components's Avatar
injectors
Thanks Mellon
This is frank the former owner of FIC I can sell the same injector to all of the EVO community as i did in the past at a fair price for the same injector as FIC and ID we all get them from the same place BOSCH .
i am not knocking anyone . I can help if anyone needs injectors PM me or E Mail me info@racecomponentsinc.com . I have a Sale Post on this Forum . Use me for any questions or help i can give
Thanks You ALL
Frank RCI
Old Jun 3, 2012 | 09:11 PM
jameswwt's Avatar
Thank you so much Guys...
Old Jun 3, 2012 | 11:34 PM
Blue91lx's Avatar
As said above, you really can't go wrong with ID or FIC injectors.
Old Jun 5, 2012 | 07:01 PM
mario1o1's Avatar
I hear ID's are where its at. Yes the FICs and ID's ARE the exact same injector. but the ID's are flow tested in large batches and are matched up in groups that have the same flow rates unlike the FIC's. All injectors are not made even. Example a FIC 2150 with a base pressure of 40psi and duty cycle of 5% may not flow the same as an identical FIC 2150 with a base pressure of 40psi and duty cycle of 5%. However it IS the same for ID's because they have been matched from the factory. The difference in price is the quality control. I'd say its worth it when your pushing this much fuel for alot of hp. you wouldn't want one cylinder to go lean or 1 cylinder to be rich. This robs HP and it can cause a potential detonation hazard.
Old Jun 6, 2012 | 06:59 AM
dc2typer01's Avatar
I would go with FIC. Their matching is extremely well. I have a set of 1100's in my Evo and i love them. Their customer service is by far the best. Any issues and you can call them up and they will help you figure it out or fix it. They have been know to take care of ID's customers when ID would no longer take care of them.
+1 for Fuel injector clinic
Old Jun 6, 2012 | 12:59 PM
JohnBradley's Avatar
I would use the FICs. You have 3 basic options in the size you are requesting, James.
FIC 900s (Hi-z)
FIC 950s (low-z)
and on the outside the FIC1100 (Hi-z)
Old Jun 6, 2012 | 06:58 PM
jameswwt's Avatar
FIC 900s (Hi-z)
FIC 950s (low-z)
Thank you Aaron & Thanks you Guys for kind sharing.
Chris, from Mellon Racing have also suggested me for FIC...
Old Jun 7, 2012 | 09:28 AM
thepoint4life23's Avatar
Is one better then the other for e85. As well what does high z low z mean.
Old Jun 7, 2012 | 01:57 PM
wjamyers's Avatar
I believe high z= high impedence = finer spray, requires a small plug and play adapter or some such. you can read all about it by searching here
mrfred
Apr 17, 2015 09:38 AM
Vivid Racing
EvoX 'For Sale' External Engine / Power
Mar 23, 2015 12:08 PM
mrfred
Apr 21, 2013 09:37 PM
jameswwt
Jul 26, 2012 06:05 AM
mrfred
Nov 27, 2009 01:19 PM
