Automatic A/C Off at WOT
Old Jun 4, 2012 | 07:32 PM
fantrman's Avatar
Does anyone have a setup to automatically turn off the A/C compressor during WOT? This would allow max power without having to manually turn off the A/C. It seems like this could be done relatively easy through the ECU by using the TPS signal and a relay tapped into the A/C compressor dash switch.
Old Jun 5, 2012 | 09:45 AM
saltydog's Avatar
the power fc does this under sudden acceleration it cuts off the a/c compressor
Old Jun 5, 2012 | 09:47 AM
n2oiroc's Avatar
most cars do this from the factory (usually above 90% tps and/or 5,000 rpm), i doubt the evo is an exception.
Old Jun 5, 2012 | 10:12 AM
fantrman's Avatar
OK thanks didn't know that. Can anyone else confirm this for sure?
Old Jun 5, 2012 | 11:40 AM
acidtonic's Avatar
I was under the assumption it does NOT do this from the factory.
With the AC on, you're low on power. WOT or otherwise.
Old Jun 5, 2012 | 11:46 AM
Boosted Tuning's Avatar
Zeitronix has a solution.
http://www.zeitronix.com/tcac/tcac.shtml
Old Jun 5, 2012 | 12:02 PM
fantrman's Avatar
Originally Posted by Boosted Tuning
Great! That's exactly what I was looking for. So, can you confirm the Evo 8/9 doesn't already do this?
Old Jun 5, 2012 | 12:22 PM
Sorry, I can't confirm if the EVO 8/9s already do this. I have heard they do and they dont.
Zeitronix will probably know, since they make that device and are in the DSM/EVO scene.
Old Jun 5, 2012 | 12:54 PM
acidtonic's Avatar
Well I owned an IX and the AC never stopped for WOT.
But I cannot cite any sources other than being an Owner.
Old Jun 5, 2012 | 01:05 PM
fantrman's Avatar
I'll see if I can tell on my drive home .
Old Jun 6, 2012 | 07:31 AM
fantrman's Avatar
OK, as far as I can tell the A/C compressor does not go off on my car at WOT or at least the green A/C dash button light does not go off. I contacted Zeitronix and they can not confirm this one way or the other, but said it "most likely does."
Here is what Zeitronix said about their TCAC (Throttle Controlled Air Conditioner) switch when asked if it can be used on the Evo 8/9:
"The TCAC switch functionality has been superseded by the ZAVT-1 Warning/Trigger box. Most vehicles now automatically turn off the A/C during performance driving - the TCAC was for older vehicles like the '92 talon which did not have this feature. The Zt-2 + ZAVT-1 can be used with a relay to trigger boost solenoid, trigger water/methanol injection, reduce timing, etc."
Old Jun 6, 2012 | 07:35 AM
n2oiroc's Avatar
How would you know, short of wiring an indicator light inline to the compressor?
Old Jun 6, 2012 | 07:37 AM
n2oiroc's Avatar
The light on the a/c button will always stay on, when the compressor cycles it doesnt go off.
Old Jun 6, 2012 | 07:48 AM
acidtonic's Avatar
The obvious power difference.
Also while tuning you can simply look at datalogs with AC on. After WOT, acceleration is much worse for the AC logs compared to AC off logs.
If the AC turned off at WOT, the logs would have identical acceleration after WOT.
neonglh
Sep 3, 2021 10:29 PM
KillaYayo
Aug 31, 2016 10:47 AM
hccyong
Mar 6, 2011 05:31 AM
honki24
Dec 19, 2010 09:12 PM
ultraflip
41
Jul 22, 2008 06:50 AM
