Fresh from honda land .... need assistance and guidance
Here is what I think I will get, unless you guys think I should get something else or maybe I'm forgetting something
14022-4 Manley H beam rods
190120 Manley 100mm crank
AMS Spec Mitsubishi Lancer Evolution IV-IX 2.3 Stroker Pistons
OEM Mitsubishi Front Cover w/ Oil Pump & Gears
MAP Timing Belt Service Kit with Water Pump for Evolution 8/9
Cometic Head Gasket / MAP Head Studs Kit (Mitsubishi Evo 8/9)
ACL Race Series Main Bearings (DSM / Evo)
ACL Race Series Rod Bearings (DSM / Evo)
AMS 4G63 Race Balance Shaft Eliminator Kit
ARP Main Studs (DSM / Evo) 4G63 207-5401
OEM Mitsubishi Evolution 8 Complete Engine Gasket Kit
MAP Oil Cooler Kit with Setrab 25 Row Oil Cooler (Mitsubishi Evo 8/9)
What sort of power do you plan on making?
The stock 100mm crank is cheap and has been proven to work to 800+whp. The turbo tuff rods or a similar I beam also seem to be popular. It all depends on power goals though.
I am not sure about the acl race bearings. I think that I heard to go with the standard for longer service intervals. I cant remember though, maybe someone much more knowledgeable will step in.
to get a stock crank around here I have to buy a whole motor and they seem to start at around 600, which is pretty much the price of the manley crank, unless you think the stock crank is better
this car will remain a sub 400 hp car
dsm nexus
27
Sep 3, 2016 02:05 PM
AkumaMotorsport
Mar 4, 2012 06:31 PM
red kryptonite
Apr 7, 2011 12:03 AM
