cracked valve guides
Old Jun 10, 2012 | 05:59 PM
chris.w's Avatar
My evo jumped time, the valves bent and cracked the valve guides. The dealership says the head has to be scrapped, does that sound right? Can they be replaced? What are my options? Has anyone had work done with MAP?
Old Jun 10, 2012 | 07:28 PM
batty200's Avatar
You can definitely replace them. The dealers don't do work like that. I would look into bronze valve guides.
Old Jun 10, 2012 | 07:56 PM
Spec-Ops1's Avatar
A reputable machine shop should have no problem replacing valve guides...
Old Jun 10, 2012 | 08:11 PM
chris.w's Avatar
So bronze valve guides. For valves, oem or aftermarket?....all of mine are ruined along with my lifters.
Old Jun 11, 2012 | 11:38 PM
batty200's Avatar
Aftermarket are less expensive. Get SS intake valves and Inconel exhaust valves.
Old Jun 12, 2012 | 04:44 AM
chris.w's Avatar
Okay, so cams...gsc s1 or s2?
Old Jun 12, 2012 | 02:25 PM
batty200's Avatar
Depends on you. S2 will make more power but you give up some drivability as cams get bigger.
Old Jun 12, 2012 | 09:12 PM
chris.w's Avatar
Are you able to elaborate on drivability?
Old Jun 12, 2012 | 10:01 PM
boostless's Avatar
How did it jump timing?
Old Jun 13, 2012 | 05:51 AM
chris.w's Avatar
The compression balance belt broke and wedged between the pulley and the timing belt causing it to slip and slamming the valves into the pistons.
Old Jun 13, 2012 | 01:20 PM
coryd's Avatar
balance shaft eliminator kit while you have it all part?
Old Jun 13, 2012 | 01:45 PM
tsidrift1's Avatar
Why take it to a dealership?? lol
Yes, valve guides can be replaced. Any decent machine shop can handle them. Go for bronze guides too.
Tsensational
Jul 27, 2016 08:53 PM
klever
10
Oct 13, 2014 07:03 PM
jameswwt
14
Jan 29, 2014 09:35 PM
Piro Fyre
Mar 22, 2012 10:27 PM
psphinx81
14
Jan 26, 2010 10:32 AM
