Quarter Masters 8 leg HTO bearing problem.
Joey (EvoSick) I guess uses the OEM pedal stop too.
And for the record my motor uses the OEM 2.0l crank.
Did you fix yours and have had an issue since???
I called quarter masters and spoke to a rep. He said they just recently started to make the slider bearings shorter then the old version. So from now on people won't have problems....hopefully
. Ima go measure the clearance again with my friend to confirm.
So are you guys saying that the TOB shouldn't be touching the pressure plate fingers, do you mean at all times? Meaning that even after you bleed the clutch line and there is pressure on the TOB should it be making contact with the clutch fingers? Or are you refering to before you bleed the line and there is no pressure on the TOB and it is sitting flush.
FS[MidWest]: Brand New In Box MAP EF3 Turbo
2006GSR
Feb 19, 2015 10:13 AM
2006GSR
Dec 21, 2014 06:43 PM
FS[MidWest]: Manley TT 150mm rods. wiseco 87mm pistons. 4g64block
2006GSR
15
Sep 3, 2014 06:37 AM
2006GSR
32
Oct 22, 2013 08:39 AM
2006GSR
17
Apr 23, 2013 03:47 AM
