Rough start, rough idle, sputtering on throttle
Old Jun 16, 2012 | 10:26 PM
Graphic's Avatar
I recently finished my build and started my car up. I broke my engine in as I was told but I'm scared to drive the car due to some issues I'm having. I recorded logs the best I could. The car dies on idle often and runs super rough. If I press the throttle down far the car starts stumbling or straight up dies. I have to modulate the throttle to keep the car running. After the car warms up the car will idle on it's own, but I pulled the throttle cable tight on the intake manifold which brings the TPS sensor to 14.58 at "idle". Base timing is at 0. Ignition timing is 14 degress. I got a base map tune from ER but they're closed for the weekends so I can't call them.
Here is a link to all my logs. The file that is 1685KB is probably the best to look at. I'm not sure what everyone wants so I uploaded all my logs.
Link to my build if this matters:
https://www.evolutionm.net/forums/ev...ld-thread.html
Old Jun 16, 2012 | 10:39 PM
okevolutionVIII's Avatar
How long was the car down during the build? If it was a good amount of time, drain the gas and check the fuel filter.
Old Jun 16, 2012 | 10:59 PM
Graphic's Avatar
1 year 2 months the car was down for.. Plugs are gapped to .21/.22
Old Jun 16, 2012 | 11:01 PM
Graphic's Avatar
I know fuel can go sour but do you think this will cause the issue? Is there a plug on the tank or am I going to have to pump the fuel out?
Old Jun 16, 2012 | 11:09 PM
There's a drain plug under the car on each side of the gas tank under the back seat area.
Here's my tank, pump and filter after sitting a while.
Old Jun 16, 2012 | 11:15 PM
Graphic's Avatar
[IMG]
I replaced my fuel pump and sock. I didn't see any debris floating around in there.
Old Jun 16, 2012 | 11:18 PM
I would still go for some fresh gas either way. Have you checked the IACV?
Old Jun 16, 2012 | 11:45 PM
Graphic's Avatar
I edited the original post for better clarification.
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
crthomas1952
May 30, 2014 09:10 AM
Noize
Oct 6, 2010 05:56 PM
