Major Problems!
Old Jun 14, 2012 | 12:10 PM
GTijoejoe's Avatar
Originally Posted by gotpsi?
Can you give a good reason why not, most people remove them on most cars not just EVO's
The screen is there for a reason, to straighten airflow through the MAF over the sensor. For the film sensor to work correctly needs to see flow in one direction only..by removing it will distort the true reading of the MAF for certain instances.... sometimes it can be more sensitive than others, depending on your setup can also make it more sensitive... sometimes you may not notice an effect.
to OP, as others have stated.... boost leak check.... I would also check the engines mechanical timing, because cam timing can also do exactly what you are describing... also if you have mevic cam timing, check that ECU table for that too just to be certain.
Old Jun 14, 2012 | 03:52 PM
Anarchy99's Avatar
Originally Posted by Ra88it
If anyone can help, I would be greatly appreciative.
The problem is as follows. To start with, i have checked all lines and hoses and all seem to be good. With that said, car just seems to be dead. When i give it any gas at all it just bogs down and sputters really bad. This is intermittent however as it will do this for a few seconds then the power will kick in but immediately start acting up again. After awhile of driving, the car feels like it barely has enough power to even leave from a stoplight.
There aren't any mods to the car and i just changed the plugs a few weeks ago. Had my local tuner update the ecu with the most up to date factory settings and the car ran fine for a couple weeks then just went downhill from there. Starting to get frustrated guys so please, HELP! Also SES light is on and throwing the P0401 code, check the vacuum lines and their good.
If you have a P0401 code, then your vacuum lines are not fine.
