Tial 44mm boost problems
Old Jun 17, 2012 | 09:46 AM
  #31
vaflyboi757's Avatar
Aiight, here's the update. I wasn't able to run another boost leak test now because I can't get a hold of a compressor today. The last time i did a boost leak test was around a month ago, so i'm figuring my egr valve vac line popped off sometime afterwards, idk but it wasn't an issue during the test. I'll try and run it once i can get a hold of another compressor again. Ok, the line i was running from the BOV to the wastegate was about a foot or so long so i cut it down and switched my boost source back to my turbo instead. I also swapped in some brand new lines to replace the old one's. And right now I'm pulling 1 spring out of the wastegate again, i'm just gonna run the 13 psi spring. After i put it back together, i'll run it again and let ya'll know if there's any differences.
Old Jun 17, 2012 | 10:03 AM
  #32
CurseDSM's Avatar
Ok there is the problem. You don't run the wg to the bov. the bov should hook into the intake mani. Take all that line out and do it this way. Run the straight side of the mbc to your boost source, take the 90 side of the mbc and hook it into the wga. Take the line from your bov and put it into the intake mani. Run it like that do a pull and report back.
Old Jun 17, 2012 | 10:13 AM
  #33
foxbear2277's Avatar
^^^^ Definently agree, wg and bov should not be connected together
Here is tials install diagram...
Notice the before and after throttle positions for wg and bov...
Hope this help you out...
Old Jun 17, 2012 | 10:26 AM
  #34
fre's Avatar
fre
Can't be the manual boost controller when he isn't even using it. Straight from vacuum source to wastegate = no manual boost controller. For testing purposes keep it this way as there are less variables. When debugging anything you always eliminate as many variables as possible.
More so than cutting the length of the line down, I would inspect it to be sure there are no hair line tears in it that won't show up under boost leak testing. Or just replace it with a brand new piece.
Old Jun 17, 2012 | 11:19 AM
  #35
Just ran it again with one 13psi spring, same thing as before 25-26 psi went running the wastegate str8 from the turbo and with the mbc. The mbc won't adjust it either, don't matter how much i turn it in. I even put a heavier spring in the mbc, no changes. To clear things up, previously i ran the wastegate to the line connecting the intake manifold and the bov, i t-ed it off. I never ran it str8 to the bov. I changed the lines from the wastegate and the turbo, there brand new silicone lines. Boost leak test is next i guess, unless anybody else has any ideas.
Old Jun 17, 2012 | 11:25 AM
  #36
fre's Avatar
fre
Do NOT use the boost controller until you have your system working without it. You are just introducing more variables that don't need to be there. Just trying to save you more headaches and wasted time. Just go straight from the side port of the wastegate to your boost source on the turbo compressor housing. You say you are using the 13psi spring. Try using the other spring instead and see what happens.
Old Jun 17, 2012 | 11:32 AM
  #37
CurseDSM's Avatar
Did you hook everything up as I have been stateing for the last few hours? You obviously have things hooked up incorrectly. Hook it up as stated or your gonna have more to fix then this simple little problem.
Old Jun 17, 2012 | 11:34 AM
  #38
CurseDSM's Avatar
Thing is he doesn't have things hooked up correctly to begin with. He needs to have everything fixed before he goes further ya know. I agree he needs to take out the mbc but until he can get things fixed this problem isn't gonna get fixed.
Old Jun 17, 2012 | 08:37 PM
  #39
b16a95eg's Avatar
My vac line controlling my wastegate is like 3'-4' long probably.
Thats What mine were with the spike I posted in the picture above, the MBC was over by where the air filter goes. I routed it now to over by the A/C line which makes it less than a foot of line, and it gave it the 2nd result.
You'd be surprised at how quick the wastegate needs to react to keep boost from overshooting
Old Jun 18, 2012 | 12:39 AM
  #40
???? cursedsm, what isn't connected right? For sh*ts and giggles I threw the mbc in the mix for one pull (as a piece of mind for me) which was routed correctly because I know how a ball and spring mbc works. But for a min now I've been trying to troubleshoot this problem without the mbc hooked up, which is leaves my turbo set-up down to just one vac line running from the turbo to the watsegate side port, thats it, clean and simple. I'm not a novice mechanic, I work on jet engines for a living so I think I can manage running a hose from one nipple to the other. I appreciate your help but please do not insult my intelligence .
B16a95eg, I also previously ran my mbc near my A/C and I still got the spike, had the line cut down to just a few inches to the wastegate and there was no changes. It would make sense for that to be the problem but ........now I'm trying to get it to work on just spring pressure (which makes the line about a foot long now anyway smh). I'm going to remove the big spring and install a small one next and see what happens, it will probably double the spring pressure again like before but we'll see. Are sticky wastegates a common thing? And if it is sticking, how can I fix that?
Old Jun 18, 2012 | 02:31 AM
  #41
evilempire76's Avatar
How are you measuring boost? Mechanical boost gauge or ecuflash?
Old Jun 18, 2012 | 02:55 AM
  #42
Mechanical gauge hooked to the TB.
Old Jun 18, 2012 | 07:17 AM
  #43
CurseDSM's Avatar
I am not tring to insult anyones intelligence here. I simply said in post 6 the correct way this should be hooked up and you neither confirmed nor denied it. Then in post 31 you go and tell us that your wg is hooked into your bov which is totally incorrect. Now with this said It still leads me to believe that something is still not connected correctly. That is not insulting anything, but in the same since your not giving me the answer I need to say ok well thats ok it is something else. That isn't insulting your intelligence, its a failure to give the info I am looking for to move forward.
Old Jun 18, 2012 | 08:46 AM
  #44
I clearly stated where I had my boost source coming from on this post, when I said BOV, you clearly misunderstood me, so I clarified, we both know that the BOV and the intake manifold share a vac line. I guess I didn't explain clearly enough that the mbc was not in the car during 95% of my troubleshoot, so I apologize for that. But its whatever bro, lets work together to fix my issue. My setup now is only running one line and thats from the turbo, to the side port of my wastegate (the mbc is out of the picture), its a brand new silicone line so I know its not split. It only has one 13psi spring in the wastegate now. The Tial is installed and seated correctly, the vband is tighten. I wasn't able to run a boost leak test yet but I went over the entire vac system with a diagram, a mirror and a flashlight, so if there's a leak, its not from a hose popping off. My next step is to lube the plunger in the wastegate, change the spring and see what happens.
Old Jun 18, 2012 | 09:34 AM
  #45
CurseDSM's Avatar
ya know being it is a 44mm it has vband correct? Check to see if the oring maybe damaged. I know I have had that happen before and it reaked all sorts of havic but mine was my bov.
