car doesnt crank stuck on the road help asap
Old Jun 16, 2012 | 09:41 PM
88888's Avatar
Exclamation car doesnt crank stuck on the road help asap
Left my car in a parking lot over night now it doesn't crank.
I checked the #1 fuse under the dash which seems to be fine.
I tried jumping the car, nothing.
My escort 8500 reads 11.7volts. All the electronic devices in car works.
Any help would be appreciated. thanks.
Old Jun 16, 2012 | 09:57 PM
fastyouth1313's Avatar
Under hood fuse box on driver side.
Could of maybe left and interior light on?
Check you starter? Is there any whine when trying to crank? Or just silence?
Old Jun 16, 2012 | 10:05 PM
88888's Avatar
I have checked most of the fuse under hood as well ll.
Its a dead silence when I try to crank.
Old Jun 17, 2012 | 08:59 AM
fre's Avatar
fre
Try jumping it with another car. If it starts and stays running, it is your battery, if it dies after starting then probably the alternator. If it doesn't start at all, then you have other issues (starter possibly).
Old Jun 17, 2012 | 11:37 AM
88888's Avatar
Jumping didn't do anything. My car doesny even try to crank.
Old Jun 17, 2012 | 11:42 AM
304MR's Avatar
Any chance of roll starting it?
Old Jun 17, 2012 | 11:55 AM
fre's Avatar
fre
I would say it is the starter then most likely. Bad starters can range from doing nothing like you are saying to just making a whining sound. You could try roll starting it like suggested above. Other than that, just order a new starter and go from there.
Old Jun 17, 2012 | 01:02 PM
llDemonll's Avatar
do the rest of your electronics work?
Old Jun 17, 2012 | 01:05 PM
88888's Avatar
Yes. Radio. headlights. Horn. It works as it should. No signs of weakness.
Old Jun 17, 2012 | 01:28 PM
97CobraMike's Avatar
i say starter if all your accesories work.
Old Jun 17, 2012 | 01:46 PM
yamahas's Avatar
man its simple!if it is starter,take a small hammer or something like that and hit it!sometimes when starter its not in a good condition it stucks!with good hits it will unstuck but its gone need servis or replace because its gone stuck again!
sorry for my english!
p.s its better when you hitting the starter put someone in trying to start that motor!
Old Jun 17, 2012 | 03:27 PM
88888's Avatar
Is there a fuse or any other potential issues I should check before I start attacking the starter?
Old Jun 17, 2012 | 03:30 PM
Bobrick's Avatar
you are pushing the clutch pedal in right?
Old Jun 17, 2012 | 03:38 PM
Liqquid's Avatar
was anything cut into the clutch pedal switch wire?
Old Jun 17, 2012 | 03:48 PM
yamahas's Avatar
no just hit it
