Oil change coming up...change brand?
Always a better idea to switch to something with more, everything will last just that much longer.
Op you will have absolutely no issue using the same oil you have been using..Anyone that tries to tell you different is a fool or a sheep
If you want to switch oils go for it but you are in no way, shape, or form gonna kill your factory motor/turbo sooner by not.
Even Forced Performance doesn't recommend Mobil1 10w-30 in their Red or Black turbo including any oil that is ILSAC approved due to lower zinc levels.
http://store.forcedperformance.net/m...otor%20Oil.pdf
That being said, the Mobil 1 0w-40, high mileage, diesel, and 15w-50 have higher levels of zinc and are good oils IMO. 15w-50 has the most. Amsoil is another good oils to run but cost more.
http://www.mobiloil.com/USA-English/...duct_Guide.pdf
Oh by the way AMSOIL also has oils that comply with the green era.
0 weight oils are too thin for the amount of power we are making and may have good cold start properties but under load it is too thin. once the polymer chains deteriorate it goes down to the viscosity of the base oil and that is way too thin. The high mileage M1 is better as far as additives go so thats a bonus if the 0-40 but it is still too thin. I have used the high mieage 15w50 in a pinch when amsoil wasnt available and that seems like the best walmart available oil.
I should say that on paper it seems to be the best choice. I have never had a failure on my evo due to oiling so far so I cant say I noticed a change per se.
I don't want to go into too much detail about this here. It can be very confusing.
My point is, 0w-40 is not "thin" in most temperatures that we use our cars in.
http://www.worldsbestoil.ca/which-30-weight-oil.php
