I'm not sure what's causing this but my car pops out of 4th gear even when cruising. I have checked my master and clutch cylinder it looks fine.
My exedy twin clutch seems to be engaging at higher point as well.
Am I going to need a new clutch? It has about!10k on it right now.
Quote:
No sir. It does not grind in any gear.Originally Posted by evodriver49
does the gear grind as you shift into it (worn/shot syncro)??
try adjusting your clutch higher takes like 5 minutes and helped me with some grinding in 4th and 5th!
http://www.evomoto.com/tech_info.php?tech_id=28
its not a clutch problem. it means slider inside trans is not making full engagement. if you are lucky could be shift cable problem. if cables are good and adj correctly then youi need tranny service to fix worn shift fork
Could be a trans problem (but dont skip over it possibly being a clutch issue) Any slipping in any other gear under WOT?
