4Th gear turned into Neutral. CLutch issue?
Old Jul 25, 2012 | 08:51 PM
88888's Avatar
Exclamation 4Th gear turned into Neutral. CLutch issue?
This all started happening when my clutch slave cylinder was leaking.
1.
I replaced my slave cylinder about a month ago due to a minor leak. I noticed the problem when the car popped out of 4th gear while cruising. lost all pressure in my clutch sooner.
2.
I replaced the slave cylinder. Car runs fine. Does not pop out of 4th gear like it used to. But i notice clutch engaging point was getting farther everytime i drove the car. it was getting higher away from the floor.
3.
4th gear starts popping out again. this happens even during simply cruising. Car does not grind going into gear. Or any gear for that matter
4.
I adjust the clutch pedal position by moving the clutch pedal. Problem gets fixed again. does not pop out of 4th
My question is
1. Could loss in pressure in clutch cause the 4th gear to pop out?
2. What could be causing the clutch pedal engaging point to keep changing? Is the clutch worn out? (15k mile exedy twin) I keep my eye out on the brake fluid. Level does not change and i do not notice any leaks.
Please help me diagnose this problem. I am out of ideas.
Old Jul 26, 2012 | 05:24 AM
94AWDcoupe's Avatar
1. no. your trans needs service. 3/4 fork is worn out.
2. your clutch is likely toast as well.
Old Jul 26, 2012 | 09:59 AM
RoMeIX's Avatar
This...you are going to need to replace the clutch.
Old Jul 26, 2012 | 08:41 PM
88888's Avatar
I want to know if its just the clutch or if i would need to pull apart my transmission as well....
I do not want to take apart doing the clutch work.
Old Jul 27, 2012 | 11:26 AM
wana-B-racer's Avatar
Change your clutch.
Old Jul 28, 2012 | 07:06 AM
88888's Avatar
any more opinions on the transmission?
bbong
Jun 11, 2017 05:25 AM
vaflyboi757
Dec 18, 2015 10:27 AM
marcusE
16
Jun 26, 2013 08:15 PM
5LEEPERISAH23I
14
Mar 24, 2013 01:02 PM
88888
Jul 5, 2012 09:42 PM
