Exedy Twin Wedge Collar pop off? HELP!
Old Mar 9, 2013 | 05:16 PM
5LEEPERISAH23I's Avatar
Was driving my evo home from work did a WOT pull 2nd to 3rd to attempted 4th gear.
I put it in 2nd shifted into 3rd gear then tried going into 4th and it locked me out. I was very confused being this is the first time that has ever done that. "This was WOT"
I instantly felt the clutch pedal lose pressure, it felt not right soft and weird. Tired pumping it, it did nothing. IT DIDNT GET STUCK TO THE FLOOR. It would not let me get into any gear, It was like hitting a brick wall every gear.
When the car is off it goes into every gear like butter. I started it in Neutral tired putting it into any gear it wouldn't let me, if i kind of forced it you would feel the car wanna creep forward a little but not go into gear.
There is no hydrick leaks anywhere, "i just put in the STM SS braided line" and the slave cylinder is working confirmed by pushing in the clutch and it is moving.
Yes i was really shifting fast doing a 3rd to 4th "locked me out"
Yes i have a clutch fork stopper on it.
Yes the Wedge Collar is double ringed.
Is it possible for the Wedge collar to still pop off?
PROBLEM FOUND! Whole Twin disk is for sale make me an offer
Old Mar 9, 2013 | 06:03 PM
ExViTermini's Avatar
Yes, have to keep up with the adjustment on the fork stopper. Even then it's possible sometimes. You can look up in the hole in the bellhousing and see what's happened.
Old Mar 9, 2013 | 06:17 PM
yea im going to do that tommorow.
i hope my trans isnt gone.. dont think it would do what it is doing if it was gone..
pressure plate?
Old Mar 9, 2013 | 11:22 PM
BEKevo's Avatar
pressure plate?
Did you ever force it into gear? If so, you'll probably need an overhaul, to replace sheared synchros.
Old Mar 10, 2013 | 11:03 AM
Turbo01s2k's Avatar
The clutch def isnt disengaging. Twins have that "chatter" when they disengage, if thats gone, nothing is open the clutch up when you push the pedal.
Old Mar 10, 2013 | 04:19 PM
nope not that dumb ha
im in the process of taking apart the trans, it should be out sometime this week, ill keep everyone posted and ill take pics of damage.
Old Mar 11, 2013 | 07:05 AM
bbyevo8u's Avatar
keep us updated, so to hear that man! how many miles on the clutch?
Old Mar 11, 2013 | 12:23 PM
i will! There was about 6,000 i think, everytime i take it out i beat the hell out of it. I did somthing really dumb last year revving it up to 5-6k slipping it to get it home for a 1 hour drive. I bet that warped the plates and it just went now im not sure.
I should have it out tommorow, ill put up another vid when i get it out or pictures.
Old Mar 13, 2013 | 08:26 AM
1/2 UPDATE: Its taking a little longer then what i expected "due to working weird hours and dont wanna get under the car by myself."
Everything is off but the Bell housing bolts and the transmission motor mount and obv. the wedge collar "double ringed" im sure that will be a blast taking out tonight.
Will post up pics if i see any damage.
Old Mar 13, 2013 | 09:51 PM
UPDATE: I got the transmission off, wedge collar was still on so it didnt pop. The pressure plate looks perfect and the fingers on it look perfect also.
My hex alan key isnt cutting it. I need to go to pep boys and get a hex socket to take off the pressure plate.
So if the springs arnt shot or the clutch plates are not warped, im kind of confused on what it could be? I really thought it was going to be pressure plate fingers or wedge collar it isnt either!
Old Mar 13, 2013 | 10:13 PM
blowngasket's Avatar
put up a pic of the pressure plate,flywheel and discs.
Hows the TOB? Clutch fork ok? are the discs Sticking?
Youll know when ya pull it apart
Old Mar 14, 2013 | 04:09 AM
Liqquid's Avatar
well that's odd... I didn't watch the video you posted but it sure sounded like wedge collar to me.. I'd test the slave cylinder have someone push the clutch in inside the car and check to see everything moves the way it should.. of course, you kinda already took all that stuff off the car though lol
Old Mar 14, 2013 | 12:29 PM
yea im going to try to get the pressure plate bolts off tonight and ill put of pics of the cluch. I think after seeing what i saw all ready somthing is worped causeing it not to disengade.
That was the first think i checked the slave cylinder is fine. I just replaced it with a brand new one 2 months ago and comfirmed it was working before i pull the tran's off.
Old Mar 16, 2013 | 05:55 AM
mrboost05's Avatar
This is the same thing my tripple did when the discs wore out around the input shaft hope you have better luck then that.
Old Mar 24, 2013 | 01:02 PM
bump! just got back from vaca, pulled the cluch off. video shown in post 1, cluch 1 is clearly done
Babs
74
Aug 13, 2016 03:13 PM
TommiM
Aug 5, 2013 06:19 PM
marcusE
Feb 8, 2012 05:45 PM
Stew
27
Jan 22, 2012 09:42 AM
