Quick de pinning question
Old Jul 5, 2012 | 08:28 AM
ihockey1's Avatar
Im almost done doing a mild tuck and im stuck on the cam sensor plugs, what do i need to use and do to pull the pins out of that plug?
Old Jul 5, 2012 | 04:12 PM
ihockey1's Avatar
anyone?
Old Jul 8, 2012 | 11:16 AM
My03evo's Avatar
In the pic theres a gap above and below the metal pin inside. Look in the bottom hole with a flash light and there shouuld be a little plastic tang clip thingy you got to pry one way to release the clip so you can pull the pins out. If you did all the other clips I assume the other connects are the same no? On the other end where the wires go in the connector there should be a rubber grommet seal, it helps to pull that out first with a pick or little flathead so youre not stressing the pin connections by using that to force the grommet out, to release the tang lock inside tho youll need a very tiny flat head or something tho, those little screwdrivers for like eye glasses should work tho
ihockey1
26
Oct 16, 2016 11:03 AM
ihockey1
14
May 16, 2014 09:30 PM
ihockey1
Jul 5, 2013 01:41 PM
ihockey1
Jan 26, 2012 03:24 PM
ihockey1
Jun 7, 2011 05:06 PM
