Evo 8 low idle, stalling when cold...
Old Jul 19, 2012 | 02:02 PM
bsh's Avatar
bsh
Evo 8 low idle, stalling when cold... SOLVED
Hello
My Evo wont idle when cold, idles when hot.
I did change the ISCV with a used one in working condition and when I started it cold, it idled very high, about 1500-1600 rpm. Now it is idling very low as it did before I changed the ISCV. It seems like the stepper only goes one way
Is there a specific procedure after installing a new ISCV?
I do have 1.3U cable.
Thanks
Old Jul 27, 2012 | 06:27 AM
bsh's Avatar
bsh
Hello
I have set the ecu via Evoscan in "BISS" mode but the rpm idle did not change when set into that mode. I have adjusted the idle rpm to about 1000-1100 rpm when hot so it dont stall when starting cold. (have to hold the accelerator about 5 sec after starting cold)
Car is completely stock. TPS is showing about 11-12% at idle.
What to check next?
Thanks
Ben Stian
Old Jul 30, 2012 | 11:34 AM
bsh's Avatar
bsh
Solved.
It was a wire near the iscv connector that was torn off...
Good to have idle working
mrfred
Aug 1, 2022 06:05 AM
simple_lancer
Oct 14, 2020 02:18 AM
hans512
Dec 29, 2016 01:15 PM
9!'clipseDOHC
Jan 9, 2016 10:21 PM
-Hum-
Mar 26, 2015 08:44 PM
