EVO 8 Cam profiles(technical)
i notice some of the cam shaft makers like to make more lift and duration on the intake can shaft and less on the exhaust side,while some builders make both intake and exhaust identical in lift and duration.
2 questions:
why do some cam makers have staggered cams and some don't?
also which is better for the EVO 8 and why?
i guess that's 3 questions actually.
2 questions:
This should help a little on your questions about lift profile
https://www.evolutionm.net/forums/ev...g-dummies.html
it had a lot about different cams and the aggressive and non aggressive like how HKS 272 is wayyyy less aggressive then JUN 272s hope it helps
