cusco vs. exedy
cusco vs. exedy
yes, did search.....not what i was looking for....
ive narrowed my choices down to these 2 cluthes...
both the dual disk version....
between the exedy and the cusco, which one should i get and why??
anybody have experience with both clutches??
thanks
thanks
Originally posted by evo542
you should get the cusco twin plate clutch because it's carbon and much easier to engage than the exedy, it also costs only about $300 more
Re: cusco vs. exedy
thanks
thanks
Chris
or almost an ACT
-non
you will not see Exedy carbon clutches anytime soon in this country, that much I can tell you (only for the 350Z)
We've got the Cusco's ready to go if you would like!
Re: Re: cusco vs. exedy
Originally posted by TalonRcR
The cusco is made by exedy and the carbon twin plates should be out very very soon from what exedy tells me.
Chris
Chris
Re: Re: Re: cusco vs. exedy
Originally posted by boostCreep
haha i was gonna say that...exedy makes cusco..and they mark em up...both will have the same performance
I still say ATS. Yes its a pretty penny but much better than a cusco or exedy. If I had to choose between the two (exedy vs cusco) I'd say cusco. It has a much nicer engagement plus it's has carbon plates.
Re: Re: Re: Re: cusco vs. exedy
Originally posted by import_speedzz
Whoa.. Foreals?.. Exedy makes cusco?.. Like same company?.. I dont think so..
Keith
Yes Cusco makes Exedy..and a few others too...it does have its differences though, disks being one of them.
As I said,m carbon Exedy clutches are out in Japan for awhile....and tons more money than Cusco's currently trade at.
ATS makes excellent units too (we also sell them, all the specs are on our site so you can see how they all compare). Is it "better" than Cusco or Exedy? I would argue a strong no - lots comes down to matter of taste and what exactly you need the unit for. The Cusco is very driveable, holds all the power most every Evo owner will realistically make. Same goes for Exedy.
ATS holds a bunch more, though the entry price is higher
Hey Matt,
You pulled 1.74's on your stock clutch. That is pretty good. Does it stink real bad when you launch like that? Mine sure did?
Brian
Brian
the only reason I would say to go with the cusco is b/c their carbon clutch is already out is usa. I think z1 is only AUTHORIZED cusco dealer in country(?), but I know on this board they are the only one. Anyway, ATS is THE clutch to get. Best reason is because it is a push-type clutch, much better IMO. It is only like 375 more the cusco double carbon...ATS holds more power, is better clutch, save for the ATS, if you're going to spend that much, you might as well spend a little more a get the best. If I didn't go with ATS...maybe OS Giken which is also push, or Ogura Racing. They are used for racing in Japan. My $.02
