high oil temps opinions please
Old Jul 30, 2012 | 07:29 PM
evoboy2006's Avatar
I'm currently seeing high of 240 oil temp from long period of driving i am running 15w40 on built motor. i am currently running no oil cooler i read up that its not needed. has anyone had problem like this? the temp outside is like 85-90 thanks
Old Jul 30, 2012 | 07:36 PM
sr20det91's Avatar
I had a problem like that one time when I drove around for about a week without an oil cooler. When I reinstalled my new one the temps went back to normal. Long periods of driving is when you will see high temps running with no cooler, You can run without one, but why??
Old Jul 30, 2012 | 07:55 PM
Raptord's Avatar
Originally Posted by evoboy2006
I'm currently seeing high of 240 oil temp [...] i am currently running no oil cooler
*facepalm
Old Jul 30, 2012 | 08:08 PM
masonh's Avatar
240* is not really too high.it's higher than stock EVO's for sure,but as long as you use a good synthetic you'll be fine.if i was running 240* everywhere i would want a racing oil in my engine,ester based or PAO base race oil.they are more resistant to heat with flash points over 400*.
or if you run cheap oil buy an oil cooler.
Old Jul 30, 2012 | 08:09 PM
okevolutionVIII's Avatar
Hitting ~220* while cruising with no cooler. Only running without one right now as I'm breaking in the engine and want all the shavings cleared from the engine before installing my recently bought new one.
Get a good cooler installed and deal with the problem being solved.
Old Jul 30, 2012 | 08:22 PM
flymx771's Avatar
You rebuilt the engine and have metal shavings?
Old Jul 30, 2012 | 08:40 PM
masonh's Avatar
i was having trouble understanding that one too.
Old Jul 30, 2012 | 10:25 PM
boostedrb's Avatar
What! Metal shavings
Old Jul 30, 2012 | 10:29 PM
Blue91lx's Avatar
Metal shavings, aka, minerals from seating your rings. okevolution knows his stuff.
If you don't have anything to offer the OP then why post?
Back on track.
Get an oil cooler.
Old Jul 30, 2012 | 10:46 PM
flymx771's Avatar
Gotcha...that's usually more of like a metallic dust that would be hard even notice during an oil change if you weren't looking for it. I guess "shavings" can be misinterpreted since most people think of somewhat large pieces of metal when they here that word.
Old Jul 30, 2012 | 10:54 PM
Blue91lx's Avatar
I got ya mayne. I was just explaining, but sounded more like attacking . That's how I can tell it's late.
Old Jul 30, 2012 | 11:04 PM
The 2 first oil changes on my built engine, the oil came out sparkly like glitter. I'm currently installing a fuel cell in which time I'll get the oil cooler installed, I don't like glancing at the oil temp gauge while only cruising and would like to drive worry-free of high oil temps.
I may also try a Tomei T-stat killer during the summer to see if my oil temps will go down but not enough to take the oil out of its proper operating temp.
Old Jul 30, 2012 | 11:12 PM
flymx771's Avatar
You're the one who had the thread on a rusted tank right? I meant to post in there that I had the same problem after letting the car sit over the winter. Ended up trying the por-15 tank sealer kit and it worked wonders! I thought it was worth a try for $70 instead of dropping a bunch of cash on a whole new fuel system. Just some friendly advice...off topic I know.
OP run an oil cooler
Old Jul 30, 2012 | 11:14 PM
Just would like to add that I've recommended to several member to do what I did. Delete the oil cooler during break-in with the STM oil cooler delete. This will eliminate any metal particles from getting getting stuck in there and coming loose later on. May not matter either way but spending $20 to make sure my new oil cooler has clean oil running though it gives me a piece of mind. The time and money I've spent on the car would make most do the same.
Old Jul 30, 2012 | 11:20 PM
The new 16 gallon fuel cell setup is almost done. The cell, pump, and lines all weigh under 15lbs which is nothing compared to the weight of the bare OEM tank. My tank was rusted to the point of not messing with it once I got a good look inside when it was removed.
