Valve Cover Gasket + Mitsu-Bond
Old Jul 31, 2012 | 04:36 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Question Valve Cover Gasket + Mitsu-Bond
Anyone familiar with using Mitsu-Bond on the valve cover gasket?
How much and where? I can't find it in the FSM.
Old Jul 31, 2012 | 05:27 PM
J_Striker's Avatar
Just a dab in the corners of the cam caps. So, 8 spots, mivec. Or 6 spots for the evo 8.
Old Jul 31, 2012 | 05:55 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Just to confirm, are these the cam caps?
Old Jul 31, 2012 | 06:00 PM
Honto's Avatar
In the corners of the 4 you didn't circle.
Old Jul 31, 2012 | 06:08 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
I see, the ends.
Old Jul 31, 2012 | 06:15 PM
EVO8emUp's Avatar
Yeah, those are cam caps, however you only need to put on the outer (4) like mentioned above. You can still see sealant on the one the top left end cap.
Make sure you clean all the old sealant and oil residue off. Use some brake cleaner on a rag to clean the sealing surface of oil.
Permatex Import Gasket Sealer (gray stuff) from the local autoparts store works just as well.
Old Jul 31, 2012 | 07:58 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Thanks for the pro tip.
Does sealant go on both sides of the gasket?
Old Jul 31, 2012 | 09:17 PM
masonh's Avatar
+1
and a dab of CA on the plug gaskets so they don't fly away when you flip it over.
Old Jul 31, 2012 | 09:34 PM
EvoFredo's Avatar
No , sealant is applied to the bare metal on the head on the inside edge of both sides of the cam caps at each corner. none is needed on the actual rubber gasket. it will sear just fine . Also another helpful tip is dont over tighten the valvecover bolts doesnt take much to make a positive seal. your not trying to hold back boost or anything , just some oil. Good luck
Old Jul 31, 2012 | 11:16 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
In case anyone else wants to see the FSM:
Old Oct 24, 2017 | 11:28 AM
FI>NA's Avatar
Bump cuz im doing this soon and this will be clutch. NECRO!
Old Oct 24, 2017 | 12:27 PM
LetsGetThisDone's Avatar
Why did you bump this? The thread fully explains where to dab the silicone for a good seal.
Old Oct 24, 2017 | 02:04 PM
FI>NA's Avatar
So other people could see it for reference, maybe click on it and learn something. Its a good thread. The more you know.
FI>NA's Avatar
Half the threads you click on do jot even have pics anymore.
Old Oct 24, 2017 | 04:39 PM
hutch959's Avatar
..... so you searched for the question you had.
Found this thread which answered your question.
so you bumpped it.
I got no problem with that.
