550 whp setup !
Old Aug 8, 2012 | 09:20 PM
Blue91lx's Avatar
If you go 6266, get the DBB version or don't run Precision.
Also, the turbo is a beast on pump:
Old Aug 8, 2012 | 09:49 PM
SDevo13's Avatar
mine is making over 550whp (dynojet) on 25psi on pumpgas (93) on a road race (i.e. conservative as all get out). . .if you are looking for just 550 I'd look at something closer to the 5858.
Also, I agree - get the dbb or don't get a pte anything...
Old Aug 9, 2012 | 06:23 AM
N33d4sp33d's Avatar
I was told by Maperformance the 6266 journal bearing is fine, only spools 400 rpm later than a dbb
Old Aug 9, 2012 | 06:25 AM
N33d4sp33d's Avatar
Originally Posted by masonh
switch to double pumper for E85,but you'll make over 500whp on 93.
I was told by my tuner, Walbro 400lph is just fine for fuel along with 2000cc injectors tuned with e85
Old Aug 9, 2012 | 06:30 AM
17pstockcar's Avatar
Yes they are find power wise
but not nearly as reliable
Old Aug 9, 2012 | 06:59 AM
N33d4sp33d's Avatar
Well doesn't Precision give some sort of warranty with their turbo chargers ?
Old Aug 9, 2012 | 07:06 AM
Yeah ofc they would. But the ball berring has so many advantages over jurnal berring that im supprised they even off them.
Im no expert but i cannot understand why you would want to get a turbo that you know is going to expire before a ball berring one "Apart from cost"
Old Aug 9, 2012 | 02:35 PM
CurseDSM's Avatar
I can name a few,
as you mentioned cost
cheaper to rebuild
no oil restrictor needed
make the same power with "400" rpm slower spool
theres a few right there.
CurseDSM's Avatar
1 year
Old Aug 9, 2012 | 02:45 PM
Blue91lx's Avatar
Originally Posted by cursedsm
I can name a few,
cheaper to rebuild
Lol it's pretty known that PTE's JB turbos are not so hot....if you're going to spend the money on a turbo why not save up and get the best one possible instead of settling for the fat ugly friend?
Old Aug 9, 2012 | 02:56 PM
CurseDSM's Avatar
but what if your desprate and thats all you can get?
Old Aug 9, 2012 | 03:23 PM
94AWDcoupe's Avatar
any turbo FP red and larger if FAR FAR more enjoyable with BB, and easier on the car when driving hard. its a must in my book.
Old Aug 9, 2012 | 04:20 PM
masonh's Avatar
only 400rpm?i would just go 6766 DBB and put down another 150whp with the 400rpm instead of going JB.400rpm is huge lag for zero more power top end.
i guess with your injectors the wally 400 will be good enough though.
Old Aug 9, 2012 | 04:28 PM
Blue91lx's Avatar
OP if you're using the 400lph for that power level, you're going to need a rewire. If you rewire that pump you're going to need an AFPR as rewiring that pump overruns the stock FPR voltage wise.
Old Aug 9, 2012 | 08:29 PM
N33d4sp33d's Avatar
Well from what I was told, the bb turbochargers can not be rebuilt, the journal bearings can be if anything was to go wrong. Are forced performance turbos more reputable reliability-wise ?
