soooo how high do you rev your stroker?
Old Aug 11, 2012 | 03:47 AM
foxbear2277's Avatar
BR2.3rpm, i plan on 9k-9.5k. .... But only if i make power up to that point
Old Aug 11, 2012 | 03:36 PM
SmurfZilla's Avatar
4G64. OEM crank. Manley Turbo Tuff Long Rods. Custom Mahle 10.5:1 Pistons. Rev limit is set up for 8k I could spin to 9k but it makes plenty of power where I'm at. no need to push it right now.
Old Aug 11, 2012 | 04:21 PM
evilempire76's Avatar
8000 rpm
AMS stroker kit Manley H-beams, Ross Pistons
4g64 oem 100mm crank
Old Aug 11, 2012 | 05:38 PM
meckert's Avatar
Your question is an interesting one--if not somewhat repetitive--. You dont ask what others are reving too- that is determined by such things as your turbos working rpm and your cams working rpm--if not your piston speed with regard to your crank. Look up the calc, you will learn some.
Lewiisz94
Feb 27, 2017 08:43 PM
babaz7
10
Jan 21, 2017 08:51 AM
SloEvo12
Dec 20, 2015 05:54 PM
BLKCarbonEVO
31
Aug 23, 2011 11:39 PM
bigturboevo80
11
Apr 25, 2011 04:50 AM
