Switching from HKS 272 to GSC 2s
Old Aug 14, 2012 | 08:55 AM
saad601's Avatar
Hey All...
As the title says, ive decided to change cams but ive got a slight problem...along with the HKS , i installed a set of Brian Crower Valve Spring and retainers....
Question is, do i need to upgrade my valve train in order to install the GSC's or would the BC work fine.
Now some background on the Car.. Im running a APEXi Tsunami Turbo Kit ( equal to a 35R ) and donot ever plan to run it over 8500 Rpm on 93 octane...
So please advise whether i should upgrade or are these enough?
Saad
Old Aug 14, 2012 | 09:03 AM
Piro Fyre's Avatar
The BCs will work fine. It's still an upgrade from stock so there shouldn't be any problems, even at 8500rpm.
Old Aug 14, 2012 | 09:09 AM
saad601's Avatar
thanks Piro Fyre... that was what i was thinking as BC is also an upgrade...and should work easily... Any1 else would like to share some thoughts on it?
Old Aug 14, 2012 | 09:21 AM
Blue91lx's Avatar
Just so you see it in here, I've been running S2s with those springs/retainers for a long time now. Many others do as well without any issues.
Old Aug 14, 2012 | 09:52 AM
saad601's Avatar
Okayy ...sorry for being a complete noob...what about cam gears? I dint have them installed on the hks as I was running a stock turbo...now that I've upgraded...do I need cam gears as well?
Old Aug 14, 2012 | 10:01 AM
boosted91t's Avatar
Don't worry about cam gears. Pick up some Kelford 272's or gsc s2's
Old Aug 14, 2012 | 10:14 AM
I-5 Evo's Avatar
I am in the exact same position as you and am in the middle of taking my head off and sending it to the machine shop for a port and polish. I would like to know how high my brian crower springs and retainers are good to rev to. I will be adding GSC no tick lifter as well because I have always hated the tick since I bought it in 2006.
Originally Posted by saad601
Hey All...
Saad
Old Aug 14, 2012 | 10:17 AM
DsmGuy86's Avatar
I've seen plenty of guys run the BC springs on numerous types of cams i think you guys should be just fine i personally got the GSC beehive springs and titanium retainers. Like Piro said i think up to 8500 rpms you should be ok
Old Aug 14, 2012 | 07:35 PM
dastallion951's Avatar
Running bc springs retainers on my old hks cams for 30 k and 15k on my s2s there good. People might knock them but in the end they are titanium. Car redlines 8k daily, according to bc there good for 9k asked them myself. Just buy gsc no tick lifters at same time
Old Aug 15, 2012 | 12:10 PM
bjstrick's Avatar
what kind of power difference can you see changing from the HKS cams to the S2's or kelfords ?
Old Aug 15, 2012 | 04:40 PM
Anywhere from 20-40 hp depending on the rpms. Lost no power downlow. Idle is more rough but still idles great with ac on.
Old Aug 17, 2012 | 11:06 AM
bjstrick's Avatar
thanks, i guess ill look into upgrading now.
EvoIXMR671
Feb 24, 2017 12:03 PM
ChicagoEvo9
48
Feb 24, 2017 02:21 AM
mrm95
21
Mar 7, 2015 02:23 AM
jnut24
Northwest Region
Sep 6, 2011 08:57 PM
stormtrooperevo
Oct 18, 2010 01:36 AM
