What Fuel Rail to use with the Full Blown TB
Old Aug 22, 2012 | 06:53 PM
n2oiroc's Avatar
Old Aug 22, 2012 | 07:02 PM
Blue91lx's Avatar
Originally Posted by psphinx81
my car made 700 on STM's mustang dyno and im still on the stock feed and return lines. my fuel system consists of:
BR fuel rail
BR double pumper
FIC 2150's
no fuel problems to date!
Oh I have no doubt that I'll be fine without that fuel line before the rail but I already cut and reflared my hard line for the -8an, so using a stock line is out of the question.
Originally Posted by n2oiroc
Wouldn't a normal swivel fitting be what I need to still run to my -8an?
Old Aug 22, 2012 | 07:08 PM
n2oiroc's Avatar
what do you mean normal swivel fitting? isnt that what you have now? i think this would clear and you wouldnt have to redo the braided line. unbolt line, toss this on and bolt line to this. done!
Old Aug 22, 2012 | 07:09 PM
EvoDan2004's Avatar
Originally Posted by boosted91t
Get an angled AN fitting for your rail.
I was preparing for a big turbo and ran out of money .
However, I already cut, put a fitting on, and re-flared the hard line in the bay, so going back to a stock line would be far too much work.
if you want a stock fuel line i have one 100% unbent and in good shape. come pick it up and you can have it.
Old Aug 22, 2012 | 09:06 PM
masonh's Avatar
do it,and i'll be right here to buy your -8an hard line.
Old Aug 22, 2012 | 09:11 PM
masonh's Avatar
you could probably put an -8an push-loc fitting and get rid of the braided line with the big ends.the push-loc ends are half the size.
i just bought a bunch of push-loc stuff for my new catch can setup,and it's a pretty sweet setup.you would just have a skinny barb end coming off the rail.i think the lines and fittings are good to 250psi,but you could clamp it if you were worried.
Old Aug 23, 2012 | 06:06 AM
Blue91lx's Avatar
Just for simplicity's sake, I'm going to grab a 120* and a 90* -8an fitting and try that first. If that fails I'll try n2oiroc's fitting, and if that fails I'll grab the stock line from evodan!
Thanks all for the help. The push loc fittings actually sound like a very good idea as well.
Old Aug 23, 2012 | 11:08 AM
masonh's Avatar
180* should move it out of the way or could you grind that nut?
Old Aug 27, 2012 | 07:25 PM
2OO3SILVEREVO's Avatar
cheap way is the already stated anl fitting or go with a boomba fuel rail setup.
Old Aug 27, 2012 | 07:41 PM
Blue91lx's Avatar
I ended up grabbing a 45* after speaking with a few folks with a similar setup. Should clear it just fine.
