Need help with build ... 6 k budget.
Old Aug 25, 2012 | 01:22 AM
codyd66's Avatar
I'm new to the forum and need some direction on my current build... I has purchased a car that was knocking and this is it's current setup
Engine:
-Stage 1 GSC cams
-1000cc RC injectors
-Evolution 9 MR BOV
-AMS Front Mount Intercooler
-Lower Intercooler pipe with Factory Upper Intercooler pipe
-Ported Exhaust Manifold
-FP Black Turbo
-3' Megan Downpipe and 3' all the way back
-Megan O2 turbo outlet housing
-Hallman Boost Controller
-CNT racing fuel pump
-ARP Head Studs
-ACT 2600
Pretty sure its tuned on stock ecu
Would like to make big reliable power on a 6 k budget. I'm new to evos so try not to crucify me.
Old Aug 25, 2012 | 02:43 AM
lostsoulsevo's Avatar
what fuel are you tuned on? how much hp do you want to make? street reliable car? track only? give us something to play with!
Old Aug 25, 2012 | 02:52 AM
GSR ONE's Avatar
Depending on how big you go will very much limit your budget, but that being said you already have some good mods. I would get that knocking worked out first.
Also big power and reliability don't really go hand in hand, so whats your power goal? I'd start from there.
Old Aug 25, 2012 | 05:22 AM
codyd66's Avatar
On 93 right now, power wise I heard a fp was good to 600-650 so I think I would like to get as close to that as possible . I'd also like it to be streetable. On the knocking issue I didn't know if I should just go and buy a build bottom end or what would be my best bet.
Old Aug 25, 2012 | 06:09 AM
Swaggers's Avatar
Veteran: Army
What this guy said. Fast, cheap, reliable. And you can only pick two. Trying to add power to a motor that is already knocking can only lead to disaster. Rod bearings aren't that much, but labor is a big cost if you aren't mechanically inclined. Fix the knock, and then you can focus on your power goals.
Old Aug 25, 2012 | 06:14 AM
codyd66's Avatar
Wanting to completely rebuild the bottom end or buy a completely built bottom end....just don't know who's built bottom end to buy besides bushur or which would be my better option .
Old Aug 25, 2012 | 06:30 AM
Swaggers's Avatar
Veteran: Army
I think it's taste and preferences at this point with the bottom end. I like the building process, but it takes a little time and mechanic ability. If you don't have either, then maybe buying an already build bottom end will be your best bet.
Old Aug 25, 2012 | 10:47 PM
GSR ONE's Avatar
I Don't think the built bottom end will resolve your knocking issues but it is a good way to start with the power goal in mind but it will take a chunk out of your budget along with other costs for labor. There are many reputable shops, Bushur, AMS, JAM, MAP to name a few that have proven built blocks. Here's a link to give you an idea about whats on offer.
Old Aug 27, 2012 | 12:18 PM
thepoint4life23's Avatar
Build a 2.3l storker and save what is left for things that break. with that motor you can have a fun street car with a lot of power
Old Aug 28, 2012 | 07:41 AM
codyd66's Avatar
From what all I read and all the info y'all have given me I think I am going to order a 2.0 long rod from bushur...... I don't know what else to upgrade with the rest of dough.
Old Aug 28, 2012 | 09:04 AM
Wait for you clutch to slip. then buy a new clutch with all the trq the black will be making
Old Aug 28, 2012 | 10:09 AM
Pssst's Avatar
well if you're doing all the work, you could use the extra dough for a stock frame turbo... like a FP Green/red/black or a BBK series or a MAP EF2/3/4 turbo...
However if you arent doing the work yourself, expect to drop 6k on just the short block. As mentioned, A clutch is a must if your planning to push more power through you motor
Old Aug 28, 2012 | 07:02 PM
codyd66's Avatar
How much trq can the act 2600 hold ? I was thinking about going gsc s2 and doing valve springs and retainers .,,, I got one of my buddy's doing the work for a good deal so my 6 k budget is for parts...
Old Aug 28, 2012 | 07:04 PM
codyd66's Avatar
Just forgot I ordered bushur intake manifold and 65 mm throttle body ..
Josh Minassian
Jun 13, 2017 06:59 PM
740 Turbo Brick
Feb 11, 2017 09:59 AM
Jenkins651
Feb 23, 2016 08:07 PM
kyoo
71
Oct 17, 2010 08:41 PM
Insanity Evo
10
Apr 9, 2010 09:26 PM
