How much can a stock Evo 8 drivetrain hold?
Old Aug 26, 2012 | 07:59 PM
Randal's Avatar
Guest
Unhappy How much can a stock Evo 8 drivetrain hold?
I have a 400whp evo 8 with a stock drive train, I am having trouble with times at the track because I am taking it easy on the launch. Should I be concerned to dump the clutch for a launch or should I feather it out?
Old Aug 26, 2012 | 08:33 PM
barneyb's Avatar
You want to go racing and not break anything. Good luck with that.
Old Aug 26, 2012 | 09:04 PM
flymx771's Avatar
You don't want to dump the clutch in an awd car it will either bog, break something, or spin the tires. The tcase won't hold up long launching with a decent amount of power like that. The stock trans can take quite a beating if you know what you're doing in terms of shifting and clutch usage.
Old Aug 27, 2012 | 01:10 AM
GSR ONE's Avatar
6 spd 260-290ft.lbs while the 5 spd is roughly 100ft.lbs more i think.
Old Aug 27, 2012 | 11:52 AM
blowngasket's Avatar
there is ways to upgrade the 5 speed to hold a bit more then that, and i say hold not SHOCK value.
Old Aug 27, 2012 | 02:32 PM
diablo1's Avatar
You should be fine, I have been running the stock drive train for around 1.5 years 30+ launches (maybe more) without a problem, if you know how to launch your car you won't break anything
Old Aug 27, 2012 | 02:51 PM
PatricksEvilEvo's Avatar
30+ launches on what clutch?
Old Aug 27, 2012 | 02:53 PM
yenny's Avatar
check out the how to launch threads in the drag racing section, talks about preloading the drivetrain etc. Of course you gotta pay to play
Old Aug 27, 2012 | 02:55 PM
itsmrrizz2you's Avatar
If you pre load the clutch n drive train properly there should be no issues with 400 as I'm making 450 and have stock trans n transfer case with 126k and still don't have any issues. There are videos here on Evo m and YouTube on how to pre load properly
Old Aug 27, 2012 | 04:05 PM
diablo1's Avatar
about 10 launches on the stock clutch, and the rest on the ACT HDSS and still running strong
Old Aug 27, 2012 | 05:03 PM
BoostNY's Avatar
How many miles are on the car? and how many of them were with 400hp? Are you racing in competitions or for personal pride?
Old Aug 27, 2012 | 06:53 PM
diablo1's Avatar
I race just for fun, the car has 62K, not all of them were at that power level, after the 400whp my stock lasted 5 or 6 then I swapped for the ACT
Old Aug 27, 2012 | 06:56 PM
flymx771's Avatar
You're walking on thin ice my friend! My 30,000 mile tcase started the death whine when it was on the dyno. Maybe 5 launches which were done while the car was stock. I wasn't really surprised considering it was making 543 ft lbs on a MD.
Old Aug 27, 2012 | 08:01 PM
diablo1's Avatar
hahaha 543ft on a MD is a LOT!!! I have 394ft on a DJ and yes I know is going to happen at some point but I think if you do it right, it will last for few passes, I have been at this power level for around 18k with no problem but the preload is key!!!
Old Aug 27, 2012 | 08:10 PM
Frank451's Avatar
