Engine forged built 10W-30 or 10W-40 synthetic oil?
[QUOTE=Jos_iQRacingEVO;10375327]
That would be a tight engine, and you can run 0w30 in the winter and all the way up to 10w30 or 40 in summer. No reason whatsoever to run a 50
You will not spin a bearing nor will you harm your engine by running a 10W30 nedless to say a
10W40 !
find out how your motor has been built from a clearance stand point, was it tight or loose ?...QUOTE]
My engine was built with same stock specs clearances. Do that make it tight or loose?
Thanks.
10W40 !
Thanks.
I would say a good rule of thumb anything above 500 to run 10w40 and 20w50
BTW: I was giving some looks to the AMS website; and I am getting interesting about it, the $ is not an issue, so that doesn't worry me, but what worry me is, if I have used Mobil1 almost for the entire life of my engine, if I do change it to another brand just like that, it will not negatively affect or contribute to a faster engine wear etc.???
You are the oil master here; absolutely true.
Ummmmmm no...
AMS website as in here??
http://www.amsperformance.com/
Not the same as AMSOIL seen here
http://www.amsoil.com/
To answer your last question no you will see no ill effect or actually any effect at all to be honest going to AMSOIL though you've been running Mobil1 the engines whole life. It'll be fine
Ummmmmm no...BTW: I was giving some looks to the AMS website; and I am getting interesting about it, the $ is not an issue, so that doesn't worry me, but what worry me is, if I have used Mobil1 almost for the entire life of my engine, if I do change it to another brand just like that, it will not negatively affect or contribute to a faster engine wear etc.???
See comments in bold
www.ams.org American Mathematical Society.
Surely if you monitor oil pressures and temperatures this can also give a good indication to what oils you can/should be running.
I have just finished running in my 4g64 forged engine in my evo 5 and i was using 10w40 mineral oil to run in which gave me about 6 bar oil pressure cold idle and about 1.5bar when upto running oil temps between 80c and 90c
When cruising at about 70mph in 5th gear i woud see 5 bar oil pressure and upto about 6 when putting my foot down upto 5000rpm+
Now i have put it fuchs 10w50 oil and i see about 7bar cold idle and just under 2 bar when upto running temps of again between 80c and 90c
And at the same cruise at 70mph in 5th gear i see 6 bar oil pressure and when i put my foot down im guessing about 7 bar at 80c to 90c
To me 7 bar when at running temps is to high what would you guys say??from what i can remembe that about 100psi
I am going to change back to a 5w40 oil i think to drop the pressures when i put my foot down and give the car better protection for the winter months ahead.
And about using a thicker oil will raise the pressure readings, vs. using a thin oil will drop the pressure readings... OF COURSE, it is a simple property of physics: At same pumping conditions if a fluid is thicker then it will create more friction and flowing pressures due to the heavy weight and higher viscosity (equals higher pumping pressure); while thinner fluids will going to flow by the same space a lot easy due that is lighter and more slippery, then the oil pump had to do less power effort to pumped it (equals to less pumping pressure); , no need to waste time on all those experiments, but I still congratulated you for all those measurements, and all that knowledge, that's very important.
now that's a good oil!
Fuchs Titan race oil is one of the best you can buy for a high hp EVO or any race car for that matter.this used to be called Silkolene and it's a great 100% synthetic ester based oil.
Motul 300V and Fuchs Titan are probably the two best oil you could possibly buy.
Well, even with all the ''racing partnership'' reputation that Motul have around the world http://www.youtube.com/watch?v=cyr3b...yer_embedded#!... do you really believe that a motor oil that comes from France are along with the best??? I don't think so. Merci.
But in the other hand Fuchs http://www.fuchs-oil.com/ is from DEUTSCHLAND, Germany, so now we are talking about the best.
Vielen Dank!!!
Last edited by Jos_iQRacingEVO; Sep 3, 2012 at 03:37 PM. Reason: Video links added.
Josi,are you trying to be funny again?
what difference does it make where it's made,it's the best.i could buy the Fuchs,but i prefer the 300V and Fuchs would be my second choice followed by Redline.
7 bar = 101.5 or 102psi aprox. Yes, you should be under 100psi.
Thanks.
I swear by any of the fuchs oil range its all that goes in my car now, I like to try keep a mental not of what oil pressures i have at certain revs as that way if a problem should ever arise.
xxevoxx
Apr 17, 2013 09:22 AM
