need info on fp black!!
so im looking into buying a bb fp black for my evo. multiple people have told me that this turbo would put me at 450 is that corect? would this be a smart choice for a daily driver or should i go with the red? thanks
There are lots of threads on this topic... However you have not posted any mods done to your car...
In any case, yes 450 is EASILY obtainable with proper mods on a black... I have a DBB black, starting the car for the first time tomorrow with it and getting it tuned, however I have a fully built motor and all supporting mods for it.
mods are :
cosworth 272 cams
pte 880cc injectors
walbro 255
tbe with test pipe
mbc
intercooler and piping
coil on plug setup
megan exhaust manifold
perrin crank pulley
head studs..
im probably forgetting some but would a black be safe on stock internals? i heard they are good for up to 500whp
cosworth 272 cams
pte 880cc injectors
walbro 255
tbe with test pipe
mbc
coil on plug setup
perrin crank pulley
head studs..
SO, depends on your definition of safe. I personally wouldn't put a black and supporting mods on a stock block I didn't have the funds and plans to rebuild when it blows.
mods are :
cosworth 272 cams
pte 880cc injectors
walbro 255
tbe with test pipe
mbc
coil on plug setup
perrin crank pulley
head studs..
cosworth 272 cams
pte 880cc injectors
walbro 255
tbe with test pipe
mbc
coil on plug setup
perrin crank pulley
head studs..
can someone tell me whats the difference between a stock evo 9 turbo and an fp black turbo? i just heard alot of good things about the fp black turbo but never found real info about it. thanks.
Black will out flow a 9. I have a black and put down 466whp and 450 tq on STM dyno by ~4500rpm @ 28psi. Have since blew my motor. Was on a single walbro 400. New plans are a BR 2.3 an double pumper. Looked down at my boost gauge and some how I over boosted never happend before hit like 34 psi. I let off but it was to late.Thinking my boost controller took a dump or froze. Lost cylinder 2 but still ran a 11.7 at 113mph in the quarter. I love the turbo. Spools pretty fast but you can also stay out of boost fairly easily which I find nice. If I were to switch I think I would go to a 6466. That looks like a nice turbo.
