Cat vs 6" Mid-Muffler - Which is Quieter?
Old Sep 4, 2012 | 10:19 AM
kyoo's Avatar
Thought I'd make a new thread instead of bumping the old quiet catback clarification thread. Any ideas on this? For both the stock catalytic convert, Stock cat with 3" ends, some of the aftermarket catalytic converts, vs a 6" magnaflow mid muffler -
Thanks
Old Sep 4, 2012 | 03:37 PM
fantrman's Avatar
Both the stock cat and the BR cat are quieter than a Magnaflow.
Old Sep 4, 2012 | 03:43 PM
kyoo's Avatar
Sounds like I'll be swapping mine out!
Old Sep 4, 2012 | 03:51 PM
fantrman's Avatar
Just be aware you will loose lots of hp. Maybe 40+ depending if you are maxing your exhaust now.
Old Sep 4, 2012 | 03:53 PM
kyoo's Avatar
That's a lot.. I've got megan o2 housing, tanabe 2.75, mid mangaflow muffler, buschur cat with magnaflow muffler
Old Sep 4, 2012 | 04:16 PM
fantrman's Avatar
Wait. You currently have two magnaflows AND a cat? That must be a quiet exhaust.
Old Sep 4, 2012 | 04:17 PM
kyoo's Avatar
sorry i meant buschur catback, not catalytic converter lol
Old Sep 4, 2012 | 04:26 PM
fantrman's Avatar
Oh Ok. That's similar to mine. You getting tired of the sound I assume? Me too. I added about 6lbs of dynomat in the trunk and it helped a little with the drone, but you can still hear the exhaust the same. Have you considered a chamber muffler and a O2 dump?. That way cruising is quiet and then open up at WOT.
Old Sep 4, 2012 | 07:07 PM
Frew's Avatar
I have two magnaflow mufflers (one rear and one where the cat was) and a magnaflow resonator in between, very quiet and straight through.
Old Sep 5, 2012 | 02:00 AM
sound77's Avatar
Hi,
Can you pls forward pic for your setup with the parts number of them magnaflow mufflers and resonator
Thanks
Old Jan 29, 2013 | 07:39 PM
kyoo's Avatar
bump for this - so i've ran the dual muffler setup (with a 6" in place of the cat/test pipe area), and I'll be trying out a HFC cat (I guess the 175 cell mil.spec)?
The new car I bought actually had dynamat in the trunk area to start - though I'll remove the dynamat on the ceiling of the trunk itself.
Old Jan 30, 2013 | 12:03 PM
cmspaz's Avatar
Note that a HFC will be quieter, but they simply cannot handle higher exhaust flows. Running over 25psi of boost on the stock turbo (or equivalent flow rates on larger) will cause it to collapse over time, to the point where it'll choke things off completely.
Old Jan 30, 2013 | 12:39 PM
kyoo's Avatar
thanks for this input - hadn't really considered that - though i won't be pushing too much air through.
Old Jan 30, 2013 | 06:43 PM
Frew's Avatar
Sorry, just realized someone asked for pics.
fugiwara
Dec 30, 2016 12:05 PM
TTBEvoX
Aug 8, 2016 12:05 PM
steve0677
Jun 15, 2015 02:23 PM
kpt6
Nov 25, 2013 09:32 PM
VRamirez2004
Oct 5, 2011 03:52 PM
