Cusco catch can issues
Old Sep 4, 2012 | 11:07 PM
xXANCHORMONXx's Avatar
So I bought a Cusco catch can I've been reading it should be vented?
Should I drill and tap a hole on the top and put a filter on it?
Any advice or should I return this.
I bought it because after I go wot like 7500K and let off the throttle i blow some smoke.
Nothing when I'm on the throttle though.
Thanks in advance
Anthony
Old Sep 5, 2012 | 03:50 AM
evilempire76's Avatar
Probably depends on your current mods and how much power you are making.
Old Sep 5, 2012 | 04:15 AM
Evoryder's Avatar
Depending on the color of the smoke, a catch can vented may be the least of your worries. You could have a bad head gasket or it could be oil you're burning up
Old Sep 5, 2012 | 04:36 AM
AngryEvo8's Avatar
I would put a breather on it.
Old Sep 5, 2012 | 09:33 AM
It's not the head gasket. Every seal was replaced. If it was a head gasket I would get smoke at wot too.
Its a light white smoke when I let off the throttle. Only happens after a long wot pull.
I make 350/315 on a bbk
wowzers
Oct 29, 2015 07:40 PM
BASHEER
Mar 19, 2009 03:16 PM
vegasevo9
Dec 21, 2006 03:12 PM
jotan82
Oct 15, 2003 09:36 PM
JT-KGY
13
Sep 13, 2003 08:57 PM
