Piston Slab @ Cylinder 1?
Old Sep 23, 2012 | 10:02 AM
jameswwt's Avatar
Hi,
helping a friend to get some advise here as he is having noise on cylinder 1 (seems like piston slab) but when the engine fully warmed up, the noise goes away.
Secondly, whenever he revs his ride pass 6,500rpm he will get some black tiny oily dots around his rear bumper.
Is it time for a rebuilt?
No sign of any white smoke.
Thanks
Old Sep 23, 2012 | 10:25 AM
CurseDSM's Avatar
Yeah sounds like piston slap. And depending on who tuned the car that black **** is just the car running rich. Its carbon deposites. Does the car throw black smoke at high rpms? Its not something I would worry about thats pretty normal.
Old Sep 23, 2012 | 11:02 AM
94AWDcoupe's Avatar
oil on bumper is a bad sign. sounds like you have a bad cylinder. do a compression check yet?
Old Sep 23, 2012 | 11:34 AM
Boostin_AWD's Avatar
+1 on a compression test. Run one cold and compare cylinders. Then run one hot and compare cylinders.
Old Sep 23, 2012 | 10:03 PM
jameswwt's Avatar
Thank you Guys for the advise and will do a leak down test asap...
illusin
Jul 18, 2014 05:45 AM
dcdirtrider
25
Jun 28, 2013 09:10 PM
AndyCT9W
Dec 1, 2012 03:16 AM
Richard Sierra
14
Mar 19, 2011 04:41 AM
