tial pinched diaphragm causing over boosting
Old Sep 25, 2012 | 01:03 AM
riceball777's Avatar
I have a twin scroll full race setup running 2 tial v44 wastegates. both wastegates have the big blue(13psi) spring in them. The problem is even with out a boost controller the wastegates are not opening until 26psi.
so I open both of my wastegates and one of them has a pinched diaphragm. This wastegate was new when I bought it so it must have been pinched from the factory.
is this causing my over boosting problem?
here are pics cuz everyone loves pics
Old Sep 25, 2012 | 01:30 AM
GotWheelHop's Avatar
It could be part of the problem. You don't have a cut in the vacuum line for your pressure source, do you? I had issues with overboost on my Green way back in the day running silicone lines like yours, and I traced it to a massive leak on the vac line to the wastegate.
As for the pinched diaphragm I could see if it has a tear in it, it might cause trouble. Put about 1-2 psi to the pressure line and see if it is leaking out. The 1-2 psi should be sufficient to see as there is no spring pressure. Good luck.
riceball777
Dec 25, 2016 07:49 PM
riceball777
Nov 23, 2016 09:41 PM
riceball777
Nov 8, 2016 02:23 AM
riceball777
17
Jun 3, 2016 08:41 AM
riceball777
For Sale - Cars For Sale
16
Oct 28, 2013 04:11 PM
