can i use redline oil for a tans oil change?>
i have the redline 70-80 mtl and 75-90 mt-90 can i use either to refill my trans after i do a clutch install? or do i need something different i know mitsu uses dia 75-85
thanks i had some because ihad someone recomend it but its been years so i want sure... m doing a clutch so ill need to add some and possibly some to my transfer case.... i have to remove the oil line to get the last long bolt on the tansfer case so ill lose oil there.... is that mtl good for the transfer case thats what i baught that **** for.....or mighta been diff in rear....
Thanks for the info id appreciate the last bit if you know
Also how many quarts does the transmission hold if i drain whats just in the plug at the bottom? i was thinking of draining whatevers in there and adding the mt90 to top it off
just to get some newer oil in there i only have 30k miles
IAmADirtDude
Dec 4, 2012 01:06 PM
