Transmission leak problem
Old Sep 25, 2012 | 11:07 PM
jason42003's Avatar
Ok so long story short I'm having a problem with my transmission leaking all of its fluid into the transfer case which then leaks it out of the passenger side axle seal. I'm going to have to tear down the transfer case to get at the seal that i think is the culprit (#30146 in the picture with red arrow pointing at it). I just wanted to hear from the transmission/transfer case gurus on if that is the seal I need to replace or if there is another seal that would cause this problem. I've already replaced the passenger axle seal and I have the o-ring for the transfer case to transmission joint that I'll throw in just to make sure but I want to order all of the parts at the same time and do it all at once instead of having to take this off a second time. So any input is appreciated, thank you.
Attached Thumbnails Transmission leak problem-oem_evo_transfer_case_to_transmission_seal2.jpg
Old Sep 26, 2012 | 03:45 AM
bigben's Avatar
Do you see those 2 o-rings (30289s and 30289p) beside the axle seal you are pointing to? Those are probably to blame, but it might be the axle seal too. I've taken my transmission down twice, and replaced both of those each time just to be safe. No leaks so far, and the last time I took the tranny off will be a year in ago this Nov.
Old Sep 26, 2012 | 12:20 PM
jason42003's Avatar
Ok I'll make sure to replace those as well while I got it down
Old Sep 26, 2012 | 08:16 PM
jason42003's Avatar
Well pulled the transfer case today n found out that the passenger side bearing let go so seals r the least of my worry, gotta have the transfer case rebuilt so it'll have brand new seals in it then haha.
TomekEVO
May 30, 2015 03:27 PM
yenny
21
Sep 12, 2012 11:28 AM
AcePitcher11
17
Feb 4, 2012 10:54 AM
211Ratsbud
19
Aug 16, 2011 08:52 PM
hotdog
14
Aug 22, 2009 09:57 AM
