Zeitronix 3.5 Bar people come in
Old Sep 28, 2012 | 02:58 PM
ihockey1's Avatar
Pretty simple question, what is the general formula to get the 3.5 bar sensor to read correctly in Evoscan. I found some formulas on here but none worked so im either entering it wrong or have the wrong formula
Old Sep 29, 2012 | 09:51 AM
Boosted Tuning's Avatar
If your using a ZT-2 or ZT-3 with the 3.5bar, and still logging from the ZT box, then you just have to log "ZTX Boost". Its usually at the bottom of the list.
Old Sep 29, 2012 | 10:20 AM
ihockey1's Avatar
Ya did that but formula isn't right, maybe I have to re install the software because the readings from ztx boost aren't correct
Old Sep 29, 2012 | 08:43 PM
norcalSRTrida's Avatar
Do you need scalar and offset? If so, in what measure of units?
If you have the AEM 3.5bar settings, they are the same for the Zeitronix.
Old Sep 29, 2012 | 10:15 PM
ihockey1's Avatar
Just the general formula, I'll try the aem one and see if I can get it to read correct, thanks
Old Sep 29, 2012 | 11:08 PM
just the general formula, i'll try the aem one and see if i can get it to read correct, thanks
psi = 12.5x -20.95
kpa = 86.18x -144.44
Old Sep 29, 2012 | 11:34 PM
When you log ZTX boost, there is NO formula. It just reads what the zeitronix brain spits out.
Old Sep 30, 2012 | 08:05 AM
ihockey1's Avatar
hmmm there was something in the eval column when i first tried so thats why i was confused. From what i read there is an x value that corresponds to a scalar 0 to 255 that is used to calculate the reading so im not sure, but ill keep playing with it, thanks for getting me started
Old Sep 30, 2012 | 04:13 PM
ihockey1's Avatar
With the formula i found im getting -8 vac and with just x i get a number just under 1000. With the formula in here "psi = 12.5x -20.95" im also getting really big numbers, so am i entering it right because the formula i found was from user RoadSpike and said to work
Old Sep 30, 2012 | 04:28 PM
Once again, if you are logging from the ZT box though the serial output, the formula you need to read "ZTX Boost" correctly is just "x". Thats it
here is a pic below
Old Sep 30, 2012 | 04:38 PM
ihockey1's Avatar
But that gives me a value in units, or some kind of value, what if I want to see boost in psi?
Old Sep 30, 2012 | 04:45 PM
Raptord's Avatar
+1 to what Jay is saying.
If you're getting a value that doesn't make sense, try using the Zeitronix software to calibrate the ZTX for whatever MAP sensor you're running.
Old Sep 30, 2012 | 05:12 PM
ihockey1's Avatar
Ok I'll give it a try, I'm using the kavlico (sp)? Sensor that comes with the kit
Old Sep 30, 2012 | 05:23 PM
Its is boost in PSI, it doesnt matter that the "Unit:" says "units". If you want, change the word to "psi". It wont change the data.
Old Sep 30, 2012 | 05:54 PM
ihockey1's Avatar
alright i will im just unsure of what reading im getting because of how high the numbers are but ill try to recalibrate and see if i can get it to read correct
3vo|3oost
May 7, 2017 01:10 AM
4b11slayer
Sep 30, 2016 07:26 AM
Evo8uk
Sep 15, 2009 02:18 PM
DrivelineSales
EvoX 'For Sale' Wheels / Tires
Jul 16, 2009 01:50 PM
tephra
Feb 11, 2008 09:09 PM
