dowel pin needed on crank??
Old Sep 29, 2012 | 10:41 PM
real fast's Avatar
I'm doing a clutch on my evo and just noticed there isn't a dowel pin in the crank for the flywheel ..is that needed ?..If so can i buy one from the dealer and hammer one in?..thx
Old Sep 30, 2012 | 06:56 AM
bigben's Avatar
I don't think you need one. The flywheel bolt holes only line up one way. The gap between the 2 bolt holes where that extra hole is, is larger than the other gaps.
Old Sep 30, 2012 | 06:09 PM
batty200's Avatar
The stock flywheel doesn't have a hole for a dowel pin. I am not sure about aftermarket flywheel but my twin disk had a spot for a dowel. I installed one then couldn't get it out when I installed a stock clutch. I ended up having to grind it down to use the stock flywheel.
Old Sep 30, 2012 | 08:04 PM
real fast's Avatar
Oh really the stock flywheel doesnt have a spot for a dowel..I'm use to working on 1g and 2g dsm's and I know people always use to say you need the dowel in there that the flywheel bolts alone aren't strong enought to hold alot of horse power ..Once those dowel's are in the crank there almost impossible to take out.
edsct9a
Aug 10, 2016 01:30 PM
kylefowlie
Nov 25, 2015 02:21 PM
jbuhrman
Jun 16, 2013 04:39 PM
Charlie-Y
May 16, 2011 07:21 PM
Chemwarrior
GSC Motorsports - Charleston, SC
11
Jul 29, 2008 08:46 PM
