Does the Evo 8 Transmission/Clutch use a Pilot Bearing?
So i am having problems with my tranny disengaing, it does not disengage at all and its not the TOB, Slave cylinder knor clutch master cylinder that has gone bad. My friend tells me the pilot bearing is bad, Is that even something the Transmission/Clutch have? What are the symptons of a bad pilot bearing?
I see, but my TOB bearing is good and disengaging fine. and its not the gear box. I will have to pull it out and see whats happening.
My car is doing the EXACT same thing, just happened last thursday night. I replaced master and slave clutch cylinders, have full pedal but when I try to shift it won't go into gear and will act as if the clutch is engaged already, like the pedal is up off the floor when it's relaly pushed down.
I am going to be taking my trans off the car next weekend. I have heard a multitude of things. Clutch fork broken, flywheel bolt (?), pressure plate springs, pressure plate bolt, etc...
If you find anything out PLEASE post it!!! I will do the same
what are your problems exactly? when you say "tranny is not disengaging" what does that mean? and what do you mean by "TOB is disengaging" neither of those should "disengage" - the TOB is locking in place and spins... it pulls the pressure plate from the clutch disk but it should always stay "engage" or you have broken your retaining clip
Like I stated above: I have pedal and we bled both brake and clutch systems. Clutch is acting like it's not being pulled back in order to shift.
Imagine you are sitting in your car. You are in nuetral not moving. You push the pedal down and start to shift into first gear. The shifter will NOT go into first, and the car will start moving forward very slowly as I push the shifter into first gear position. It will not go all the way in, but will fight and the car will move forward.
Make sense? I can't describe it any better than that.
*EDIT*
aaaaand I just saw that you were talking to the OP, lol. My bad. But my post remains vaild!
*EDIT*
I'm gonna go with air in the clutch line. Most people think they have it bled completely, but they don't. When I got my Motive power bleeder for my brakes, I did the clutch line as well. I know it was bled properly this time because my brake pedal has never been this stiff the entire time I've had the car (over 4 years).
Clutch enganged
I've talked to a few people and got a couple more ideas, none of them really good to hear, lol. Flywheel bolt on my buddies car backed out and took off some flywheel teeth. Another one is the clutch disk springs may have fallen out and are loose.
I've bled the system, I've adjusted the clutch and I am still right back where I started as well. Chances are high it's going to be something to do directly with the clutch disk/pressure plate or flywheel.
Thats exactly what i was thinking, maybe a lose bolt or something. I will bring down the tranny this weekend. If its a lose bolt Locktite blue compound will fix that
. But hopefully its nothing major.
use red loctite on flywheel/pressure plate bolts. I think if a flywheel bolt backed out you would have way more serious problems such as pieces of a flywheel sticking through your hood... flywheel bolts coming loose is generally a catastrophic failure
