Clutch Issue??
Old Oct 8, 2012 | 08:36 AM
mr-roy's Avatar
Clutch Issue??
Car won't go into gear when its running, clutch has alot of pressure,slave cylinder and master are fine. Car goes into gear when not running. Clutch is fine car does not slip, car can be driven through gear and rpm shifting clutch pedal uselsss. Its not throw out bearing, i think maybe pressure plate. I can boost in 5th hard but no slip. Car shouldnt be driven but can be carefully and skillfully. Clutch ped feels great/normal, but the only time i use clutch is to start for sensor to turn over. I park on hills i start in neutral then rev and it pops in first then im off and good to go and can drive through dropping the rpms
This a question a friend is asking about his Evo, any help?
agtpony
Mitsubishi TC-SST Discussion
May 22, 2014 01:18 PM
vito93
Dec 8, 2013 06:36 PM
novec64
24
Oct 1, 2011 11:00 AM
Nomad4g63
Nov 16, 2010 10:37 PM
DSMEVOLUTION
Oct 8, 2007 08:40 PM
