Low/Poor idle and stalling when cold.
Old Oct 18, 2012 | 12:19 PM
chrisff521's Avatar
My evo 8 has a terrible idle when cold. It will idle so low that it just ends up stalling. As the engine warms up, the idle stablizes and idles very smoothly. Car is stock except for TBE, LICP, and MBC. Stock intake and UICP. I replaced the Iacv and it had no effect. Same problem. I went into SAS mode in ecuflash and set the base idle and its the same. I dont know what else to try???
Old Oct 18, 2012 | 01:26 PM
JohnBradley's Avatar
What is TPS percentage set to at idle, what are the AFRs, this is a MAF car I take it?
Old Oct 18, 2012 | 01:44 PM
chrisff521's Avatar
Yes Maf, tps at idle is 12-13%. I dont have a wideband as of now. I was planning on getting one in the next week or so. Do I really need a wideband to diagnose this?
Old Oct 18, 2012 | 03:49 PM
gprix1's Avatar
Have you done a boost leak test to make sure it's not a small leak somewhere after the MAF?
Old Oct 18, 2012 | 06:28 PM
the other thing that could cause this, least in my experience, is a dead O2 or lazy O2 that keeps it in open loop when cold and DEAD lean. It sorts itself out when warm since a stock injector car will run at the same AFR when there is no O2...more or less.
Old Oct 19, 2012 | 09:44 AM
Evoryder's Avatar
May need to mess with your idle settings based in coolant temp. I had similar issues years ago and upping the values based on coolant temp fixed it.
Old Oct 19, 2012 | 07:27 PM
bigkert's Avatar
Try changing you oxygen sensor!
Old Oct 19, 2012 | 08:22 PM
Raptord's Avatar
Log o2 sensor signal before replacing it to see if it's working normally or not. The signal should continually cycle from rich, to lean, back to rich, etc.
Old Oct 20, 2012 | 08:04 AM
chrisff521's Avatar
Ill try logging the o2 today and see what happens.
Old Oct 20, 2012 | 08:39 AM
chrisff521's Avatar
The sensor is reading from what I see. Startup it's 8-12% and then start to lower as it warms up to between -2% ~ 3%. Should I just try messing eith the iac steps?
Old Oct 20, 2012 | 08:52 AM
Raptord's Avatar
I meant to log actual o2 sensor voltage, not the STFT. Sorry, my fault for not being specific.
Old Oct 21, 2012 | 06:30 PM
chrisff521's Avatar
what should the voltage be readuing at idle? I actually just got a wideband and the AFRs are very lean at idle. Going as high as 17-18 at idle. It will get rich around 12 randomly for a few senconds and then back up to 15-16 most of the time. Thats at normal temp idle. Initial startup/Warming up its so lean it sometimes wont even read on the WB.
My AFR map is 14.7 at 500RPM and 1000RPM,
Old Oct 21, 2012 | 06:57 PM
Raptord's Avatar
it should constantly go from .1 to .9, then back to .1, etc.
Old Nov 22, 2012 | 12:26 PM
chrisff521's Avatar
The voltage cycles from .1 - .8 when warmed up but right at startup it stays around .5 - .6
Old Nov 24, 2012 | 08:29 AM
chrisff521's Avatar
does that indicate that the o2 might be faulty?
