Low/Poor idle and stalling when cold.
Old Dec 19, 2012 | 07:46 AM
chrisff521's Avatar
I tied running the car in open loop but it still did the same thing at idle so I'm guessing the o2. Is good? I'm really thinking its the iac. I may have just bought a bad replacement being used.
I took the iac out and turned the key to on and the isc resets itself like normal but could it still be bad even though I get a response from it. Also when tryin the sas test in evoscan, the isc does absolutely nothing for the idle. And any changes to the iac stepper table does nothing. Neither the iac vs coolant temp tables.
Old Dec 20, 2012 | 05:36 AM
BkzProblem's Avatar
When was the last time you checked your plugs? What kind of plugs are you running? And have you checked your fuel pressure?? Try swapping a set of brand new plugs and see if it improves.
Old Dec 20, 2012 | 10:02 AM
chrisff521's Avatar
Yea just changed the plus recently. Definitely not the issue though.
Old Dec 20, 2012 | 11:54 AM
whiteEvo08Y's Avatar
Following the thread forsure. Have same problem.
Old Dec 20, 2012 | 04:44 PM
chrisff521's Avatar
Have you tried replacing your iac?
Old Dec 21, 2012 | 06:35 AM
Do you think it will help if i changed the IAC? I thought maybe the TB senor. I Just don't feel like spending $300-400 on a IAC And it wont fix it. What do you recommend?
Old Dec 21, 2012 | 07:09 AM
Raptord's Avatar
I have a spare, used IAC for sale if you're interested. Just need to get it back from the person that borrowed it.
That said, you might want to check this thread beforehand, especially the more recent pages. Domyz and Jamie @ Dynotech are discovering more and more how the idle system works: https://www.evolutionm.net/forums/ec...ssembly-8.html
Old Jun 27, 2018 | 11:38 AM
Sawnti's Avatar
Fix?
My evo 8 has a terrible idle when cold. It will idle so low that it just ends up stalling. As the engine warms up, the idle stablizes and idles very smoothly. Car is stock except for TBE, LICP, and MBC. Stock intake and UICP. I replaced the Iacv and it had no effect. Same problem. I went into SAS mode in ecuflash and set the base idle and its the same. I dont know what else to try???
hey just bought an 04 evo 8 with this same issue. I've searched tons of threads and haven't ran into anything similar but yours. Rough cold starts. Like idling at 500 to 700. But when it warms up sometimes it will idle fine at 1k to 900 or sometimes it will still idle at crap like 700 to 800.
mods. Were you able to fix this issue yet?
tomei catback
jd carbon coil packs
hks ssqv bov
Ets intake
AGP 3.5 intercooler
koryo rad radiator
Old Jun 29, 2018 | 06:10 PM
WOT's Avatar
WOT
the old 03/04 iac's are not that great. try to find a used one from an 05/06. they have a "top hat" style plunger that lasts longer & controls idle better
SunnyC
Apr 14, 2020 05:21 PM
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
bsh
Jul 30, 2012 11:34 AM
foxbat
Jun 25, 2012 08:45 AM
hotredevo
Jul 29, 2010 06:54 AM
