What is the most whp made on a 2.4L with 100mm crank?
Old Oct 30, 2012 | 08:14 PM
  #31
Sharkbite2000's Avatar
I had a 2.3L and I maxed out 6765, 6262 and a few other turbo's that got blown up in the process never had a engine failure and got to sell the car
Old Oct 30, 2012 | 09:52 PM
  #32
jessmanEVO's Avatar
This is what I like to hear
Old Oct 30, 2012 | 10:05 PM
  #33
2006GSR's Avatar
What was the engine setup and what hp did you max out the 6765 at?
You guys are making me think twice about making more power then what i have now. **** it blows it blows. ill do a 2.1L =D
Thanks
Old Oct 30, 2012 | 11:28 PM
  #34
mynx87's Avatar
I'm in the process of a 2.4L build looks like I'm gunna add a forged crank to the list be4 they put my motor together thanks for the insight guys this is why I love our community
Old Oct 31, 2012 | 05:48 AM
  #35
SmurfZilla's Avatar
Originally Posted by blackenedwings
It seems like for the peace of mind building a stroker 2.3L or 2.4L going with a billet crank is the way to go. I guess I'll be going with a K1 crank for my 2.3L.
Billet is kinda overkill unless its going for 800+ in a mostly harsh environment (Drag or track racing), no?
Old Oct 31, 2012 | 08:38 AM
  #36
blackenedwings's Avatar
It's a track car that will eventually be running 550+ whp at WOT for relatively long periods of time. I have a built head and don't feel like cracking this motor open once I'm done if I can avoid it.
Old Oct 31, 2012 | 09:09 AM
  #37
Thanks
848awhp at 50+ psi race gas.
680ish Pump Gas
Old Oct 31, 2012 | 09:12 AM
  #38
2006GSR's Avatar
680ish Pump Gas
What was your setup on your 2.4?
Thanks
Old Oct 31, 2012 | 09:17 AM
  #39
Originally Posted by 2006gsr
what was your setup on your 2.4?
Thanks
2.3l
Old Oct 31, 2012 | 01:17 PM
  #40
JohnBradley's Avatar
Torque has as much to do with it as power...that and RPM.
aaron
Old Oct 31, 2012 | 01:47 PM
  #41
jessmanEVO's Avatar
@aaron what do you recommend is a safe rev limit for a standard 2.4?
Old Oct 31, 2012 | 02:13 PM
  #42
Our recommened limit for the standard rod is 8k and 8500 at the track, I normally allow 500 more for the LR2.4 and have personally spun my LR2.4 to 9100 when I had the 3794 on it. I dont recommend making that a habit unless you are willing to pay the piper.
Old Oct 31, 2012 | 03:34 PM
  #43
Originally Posted by JohnBradley
These days we have started running the K1 and will see where that goes. Plenty of options out there though.
Is that your recommended billet option for 2.3L and 2.4L motors then? I've heard pretty positive things about the K1 cranks, and my motor builder suggested it for my 2.3L.
Old Oct 31, 2012 | 03:58 PM
  #44
I have used Eagle in the past and there were things I wasnt stoked about with the machining. We have looked at the Manley stuff in more detail and the K1 most recently. It is not an inexpensive piece but it has Kiggly's seal of approval so there was a reason we went with it
Old Oct 31, 2012 | 05:59 PM
  #45
Spec-Ops1's Avatar
Aaron K1 is a sub-company of JE/Wiseco correct?
