Need Advice, Cylinder One Leaning Out
Old Oct 29, 2012 | 10:19 AM
Teal2nnr's Avatar
Background: I put a brand new built motor in my car this year. I had it tuned on 94 octane on a very safe and extremely rich tune (pours black smoke out the back when i’m heavy in boost). Fuel system wise it has a BR double pumper, Aeromotive FPR, FIC 1250 injectors, stock fuel rail. The car is running 25PSI out of a 6262 .82 turbo, stock ECU speed dencity. .
Whelp I put my car away for the winter, in doing so I pulled all the spark plugs and fogged the cylinders with oil. So naturally I check the condition of the plugs to see what they were like. I was assuming they would all be black with carbon as the car is running uber rich. The spark plugs in cylinders 2-4 were as expected, very black. Cylinder one however was white indicating a lean condition. As of right now i’m not sure why.
Could this be due to me using a stock fuel rail?? Is its something to do with my stock intake manifold?? The car is away for the winter, so I can’t test anything out...but I wanted some advise on things to try.
Any thoughts??
Old Oct 29, 2012 | 08:08 PM
VIIIdriver's Avatar
I think it has to do with the stock intake manifold design, i have seen this happen quite a bit with the stock intake manifold,including my own car,i have a FIC fuel rail so that's not the culprit,i always run my engine on the rich side to compensate for it.
Old Oct 29, 2012 | 08:23 PM
jdmeg6's Avatar
Send your injectors to RC engineering and verify that number one is flowing as well as 2-4. If its not that could be causing your lean problem.
Old Oct 29, 2012 | 08:35 PM
Teal2nnr's Avatar
Its just off since the injectors are brand new....I'll be looking at the fuel system and intake manifold. Hopefully one of the two is the culpret. I just thought there might be something i'm overlooking.
Old Oct 30, 2012 | 07:40 AM
Teal2nnr's Avatar
No one else has ran across this?? I find it odd since the car before the build ran great, all the spark plugs where a nice brown colour.
Old Oct 30, 2012 | 07:54 AM
JohnBradley's Avatar
Swap injectors into a different cylinder and see if the "lean" look follows it. If it does then its injector, if it doesnt then its airflow in the manifold. Cylinder one is at the back of the intake manifold (furthest from the throttle body) so typically it gets a little less airflow which would go rich. It is also the last on the fuel rail but I have never seen that make a difference.
Old Oct 30, 2012 | 10:24 AM
Teal2nnr's Avatar
Thanks, thats a good idea. I'll do that.
Old Oct 30, 2012 | 10:29 AM
EvoLutionized8's Avatar
excellent advice as usual from johnbradley. we have had multiple issues from FIC injectors lately. Im on my second set and they were brand new as well.
Psybin
Evo X How Tos / Installations
Aug 29, 2014 12:41 PM
EvoLeoIX
64
Feb 8, 2014 07:45 PM
jason42003
Jan 20, 2014 12:34 PM
Bassicfun
For Sale - Cars For Sale
42
Nov 25, 2012 12:46 PM
GGevo921
For Sale - Part Outs
208
Nov 9, 2012 07:22 AM
